Epic B and O
Forum Replies Created
Viewing 14 posts - 1 through 14 (of 14 total)
  • in reply to: Beocenter 9500 controller PCB assembly #69489
    Epic B and O
    Many thanks
    much appreciated
    in reply to: Beocenter 9500 controller PCB assembly #69413
    Epic B and O
    Hello
    Can anyone tell me what this part is called?
    All I know it’s for a Beocenter 9500
    Many Thanks
    michael
    in reply to: Beocenter 9500 controller PCB assembly #61214
    Epic B and O
    Hey mate
    i haven’t.
    when you keep your finger on the rubber bumper, they flash for a second
    michael
    in reply to: Beocenter 9500 controller PCB assembly #61200
    Epic B and O
    Hey mate
    Thank you for your reply
    Unfortunately it’s not the glass, because the buttons are still not working when you touch the rubber bumpers directly
    Regards
    Michael
    in reply to: Beocenter 9000 button fault #60361
    Epic B and O
    Thank you so much.
    I will check the ribbons and the connections.
    All else fails, I have found a Hi-Fi service in Perth WA. Hopefully they know their way around Bang and Olufsen.
    Just want it to work and sound like it did when I bought it in the 90s
    in reply to: Beocenter 9000 button fault #60353
    Epic B and O
    Thanks for your reply mate.
    The buttons aren’t working even with the glass panel removed.
    I am worried I damaged a wire or board when trying to prop up the cover.
    I don’t have the remote anymore unfortunately.
    Also apologies, it’s a Beocenter 9500
    in reply to: Penta unusual loud noises. Like loud Scratching #52862
    Epic B and O
    Hey mate,
    I have the same problem. It’s  corrosion on the input level switch.
    I had a complete overhaul of my Penta’s, but unfortunately they missed the switch. So at the moment I’m living with it by switching the problem speaker to another input level.
    I have the Beocenter 9500 also since the 90s. Absolutely love it.
    I’ve attached photos of the problem switch.
    if you find a fix please let me know.
    hope this helps.
    in reply to: Beocenter 9500 sound problems #48911
    Epic B and O
    Ordered 4 new drivers from Austria.
    Hopefully this fixes the muffled sound.
    Another thing I noticed was that the tweeters would occasionally cut out. I’ve checked the connections, and they all seem ok.
    in reply to: Beocenter 9500 sound problems #48909
    Epic B and O
    Thank you for your help mate.
    To be honest I think I’ll just buy new drivers. Had these speakers since the 90s, and want them to sound like new.
    One thing I noticed which I’ll recheck later, was that there wasn’t much sound coming from the tweeters. If there’s a n issue with them, that would also explain the muffled sound.
    I’ll check the 8pin din sockets also
    in reply to: Beocenter 9500 sound problems #48907
    Epic B and O
    Many thanks for your help mate
    in reply to: Beocenter 9500 sound problems #48905
    Epic B and O
    Can you recommend a good quality foam kit?
    I live in Australia
    in reply to: Beocenter 9500 sound problems #48903
    Epic B and O
    Yes it wasn’t done by a professional unfortunately.
    I will order new drivers off eBay. My only concern is the part numbers don’t exactly match. The one’s on eBay are 8480232, and mine is 8480239
    in reply to: Beocenter 9500 sound problems #48900
    Epic B and O
    The cables between the Beocenter and Beolab are new, but I’ll check the sockets for the 8 pin din cables.
    I did connect my Penta speakers to the Beocenter, and they sounded ok
    in reply to: Beocenter 9500 sound problems #48899
    Epic B and O
    Thank you for your help.
    Yes I did notice that one of the speakers drivers had a split in the foam, but would that cause both speakers to sound muffled?
