Beatrice assiana
Forum Replies Created
Viewing 1 post (of 1 total)
  • Beatrice assiana
    Beosound Core + Beolink Converter NL/ML + Spotify Connect issue (MasterLink distribution)
    Hello everyone,
    I have a hybrid Bang & Olufsen setup combining older MasterLink products with newer Network Link products, and I am trying to understand whether I am facing a configuration issue or a technical limitation.
    My current setup:
    Beosound Core (older version, not the new 2024 version)
    Firmware version: 1.4.6.1
    Beovision Horizon (Network Link)
    Beovision 10-40 (MasterLink)
    Beosound 3500 (MasterLink)
    The Beolink Converter is configured as:
    ML role: A Master
    Primary product: Beosound Core
    Secondary product: Beovision Horizon
    Current observations:
    1. B&O Radio via Core works perfectly
    I mapped B&O Radio from the Core to RADIO on MasterLink.
    Result:
    Radio plays perfectly on Beosound 3500
    Radio also works on BV10
    Stable playback, no interruptions
    2. Bluetooth streaming works
    If I stream music from my phone to the Core using Bluetooth:
    The music is distributed correctly over the ML system
    Playback works on Beosound 3500 and other ML products
    So NL to ML audio distribution is working.
    3. Spotify Connect does NOT work
    When I start Spotify using Spotify Connect directly to the Core:
    Spotify starts correctly on the Core
    The Horizon can play the Spotify stream
    But:
    The ML products immediately stop receiving audio
    If I select N.MUSIC (mapped to Core → Music) Spotify stops immediately
    No sound is distributed to MasterLink products
    I also tested this while B&O Radio was already playing over ML.
    Scenario:
    Core playing B&O Radio
    ML system playing radio normally
    Start Spotify Connect to Core
    Result:
    B&O Radio stops immediately
    Spotify does NOT continue on MasterLink
    ML audio disappears completely
    Important:
    Bluetooth streaming DOES work.
    Spotify Connect DOES NOT work.
    This seems Spotify-specific.
    My question:
    Is this a known limitation of the older Beosound Core + Beolink Converter NL/ML combination?
    Or is there a specific BLC configuration that allows Spotify Connect to be distributed over MasterLink?
    At this point it seems that:
    B&O Radio = works
    Bluetooth = works
    Spotify Connect = immediately breaks NL → ML audio distribution
    Any ideas would be greatly appreciated.
    Thank you.
    Has anyone else faced similar issues with the Beosound Core and Beolink Converter? What configurations have worked for you?
