Forum Replies Created
Alexey Malyugin
BRONZE MemberHello! I tried two audio converters:
PALMEXX optical-to-coaxial converterNoname Bitstream optical-to-coaxial converter
I also tested directly with a DVD player. When connecting the DVD, the sound came on immediately! The sound system displayed Dolby Digital 2.
When connecting through either of these converters, the display shows “Mono/Stereo,” but there is no sound. I tested with both Dolby Digital and PCM on the LG.
The support service of both converter manufacturers replied that PCM settings are required. In other words, the signal is transcoded into PCM, and the processor should process it, which, apparently, is not happening with my BeoSystem 3.
My conclusion: I need a converter that will transmit the signal unchanged, simply converting Toslink to Coax.
Having searched the forum, I did not find a single example of a confirmed working converter. Could you help me choose one that definitely works?
I know one nuance: BeoSystem 3 accepts only standard Dolby Digital (not DD+) and 48 kHz.
Alexey Malyugin
BRONZE MemberHi,
You must use the input that you have assigned the remote control to. I am not sure if the Mk3 has the same menu as the Mk1. Maybe you can get hold of a reference manual?
Below a couple of screenshots of my settings:
I assigned the S/PDIF input to the TV command on the remote:
Then under OPTIONS/SOUND, you can see how I listed my speakers, their roles, and their volume & distance settings, also that I want to use all speakers for video use, and 2 speakers for audio use (SPEAKER 5 / SPEAKER 2)
Are you not using a centre speaker? Could it be to better use another powerlink socket? The first two are dedicated to center and sub:
That is pretty much it I guess!
Hope this helps,
Regards JohanI will attach screenshots, as I think the issue might be with the source. This is because standby lights up orange after 5 seconds.
You must be logged in to view attached files.Alexey Malyugin
BRONZE MemberWhen you set the ‘TV SPEAKER LEVEL’, do you hear white noise from the speakers? I ask this as you say that they do click.
J.
No, they only click when their roles are selected.
Alexey Malyugin
BRONZE MemberHi, mine is Mk3.
I am using the AV2 S/PDIF sound input on the BS3 (under CONNECTIONS)
The sound out setting of the LG is ‘optical out’ and ‘passthrough’
My BS3 is in V.OPT 2
Have you assigned speaker types and roles? (under SOUND SETUP)?
And ‘default video speaker’ (under SOUND ADJUSTMENT)?
J.
Can I plug into any S/PDIF input?
I switched to AV1 (it’s active in my service menu).
In LG, I selected optical and passthrough.
Speaker types and roles are assigned—speakers click when selected.
There’s no ‘default video speaker’ option under Sound Adjustment for me. I’m attaching a screenshot.I’d like to note that the BS3 is almost always in standby mode (flickering orange), as if it’s not receiving the correct sound.
BRONZE MemberHello Alexey,
I also have an LG TV connected, a C9 55″, to a BS3 (mk3).
I use a super simple optical (toslink) to coax converter. All works fine, feeding 6 Beolabs through Powerlink.
Do you have Powerlink to RCA cables for the Beolab 8000s then? And you say that the Beolabs show orange leds? Orange leds are not usual and indicate an issue – they should be red (off) or green (on). Do you have Beolabs that work with Powerlink to try? Could it be that the volume coming from the BS3 is too low to trigger the RCA fed Beolabs?
There are some more threads around this, including screenshots of the LG sound output options and the BS3 input options, such as this one: https://archivedforum2.beoworld.org/forums/p/43717/316931.aspx, hope they help to isolate and fix the issue.
Regards,
Johan
Do you have an MK1? Which SPDIF input are you using? How does A.OPT/V.OPT work? In LG, do you select Dolby Digital and PCM?
Alexey Malyugin
BRONZE MemberThank you for the response and the link, I’ve read it all. However, this doesn’t quite fit my case. I still want to use BS3 to pass digital audio to BeoLab 8000. I connected via RCA like this: TOSLINK from LG to a DAC → RCA to BeoLab 8000 (Line mode), and it works perfectly.
BeoSystem 3 is glowing orange. BeoLab always shows red. Powerlink is available, and that’s how I’d like to connect.
From the options I tried:
- HDMI Extractor – HDMI eARC/ARC to extractor → Coaxial to SPDIF on BS3. No sound.
- TOSLINK-to-COAXIAL converter – No sound.
- DAC (with TOSLINK-to-COAXIAL function) – No sound.
I suspect I might be mistaken with the settings or modes.
It also worries me that AV4-AV6 are not listed in Monitor Information, even though I’m connecting to AV5-AV6.
You must be logged in to view attached files. -
