Home › Forums › General Discussion & Questions › General Discussion & Questions › wiring diagram
- This topic has 2 replies, 3 voices, and was last updated 2 years, 5 months ago by
Steve at Sounds Heavenly.
18 October 2023 at 01:29 #49742
VinceV
BRONZE MemberCan someone guide me to wehere I could find wiring schematics for a DIN 7pin connector (Beogram4500) to two RCA connectors please?
18 October 2023 at 13:46 #49743 Guy
ModeratorYou want the Beogram output DIN pins 3 and 5 to go to RCA Left and Right respectively. Pin 2 is ground.
But if you are making your own lead and only have a 5 pin DIN socket you will need to removed DIN pins 6 and 7 (they unscrew).
EDIT: Pin numbers looking into a 7-pin DIN socket (or looking at solder side of DIN plug):
I would be tempted to purchase one of these ready made leads from our site sponsor: https://soundsheavenly.com/beogram-record-players/14-2244-beogram-to-non-bo-device-phono-pre-amp-receiver-amplifier-etc-bo-ref-.html#/2-length-1m/60-grounding-internal_ground_link
18 October 2023 at 17:50 #49744 Steve at Sounds Heavenly
GOLD MemberHi VinceV,
Incorrectly grounded cables are the most common cause of noise when using turntables. The cable that I make (linked in Guy’s message above) is the same one that I make for B&O to use on the Beogram 4000c and Beosystem 72-23, so you can be certain that this is made to the very best quality and correctly wired.
Kind regards, Steve.
