Home › Forums › Product Discussion & Questions › BeoLab › Wireless PL with Beolab 8
- This topic has 6 replies, 2 voices, and was last updated 16 hours, 20 minutes ago by
beotex.
9 January 2024 at 07:56 #52062
beotex
BRONZE MemberI bought a BL8 (single) and very impressed with it so far. I’m considering buying a second to use with my TV setup, but having trouble testing it as a wireless PL speaker.
Current setup is Avant NG, BL18’s in front (WISA), BL19 (WISA), and two speakers in the ceiling for surround (PL connected via Passive amps).
The TV discovered the BL8, and I added to a speaker group. But, no matter what speaker role I assign, no sound is coming through it. I only hear sound in the setup “noise” to identify the speaker for assigning the role.
Do I have to use a pair to be able to use them in a WISA / Wireless PL mode? Is there some setting I need to check to enable? I have “Wireless Power Link” selected in the “Speaker Connection” setting in the app – anything else?
Thanks!
My B&O Icons:18 January 2024 at 21:52 #52063beotex
BRONZE MemberAs a follow up, I haven’t figured out the connection of the BL8, but… I did do a lot of experimenting with the different settings / speaker groups / etc. All this left me even more perplexed.
I also grabbed my Beolab 2 from the other room to see what it would be like to have two subwoofers. I wired it through a physical powerlink cable. The TV recognizes it and works, but the BL19 shuts off. I tried assigning both to Subwoofer, then one to Sub Front and one to Sub Rear, and all combos of Sub combinations, and only one subwoofer would play. Some groups it would be the BL2, others it would be the BL19.
Any ideas on how to use both a BL2 and BL19 with the Avant NG? Does it make any difference that the BL19 is WISA and the BL2 is wired?
All my test setups have been in “TrueImage” and not “1:1”. I also tried 1:1 in a couple of tests without any luck.
My B&O Icons:30 July 2024 at 04:50 #57783beotex
BRONZE MemberStill trying here…
I picked up a second BL8. Same issue with the Avant NG. I even tried hardwiring into PL for the speakers and get the same results. I can see the speaker connected as wireless, it makes the “noise” during speaker role determination, but no sound otherwise.
Really frustrating to have these new speakers and not be able to add them to my surround setup.
My B&O Icons:13 August 2024 at 19:58 #58253Beouser19
GOLD MemberHi
Beolab 8 doesnt support VE 1.0 and 3.0 with Wisa (avant/avant ng/horizon etc
but with powerlink cable it should work
19 August 2024 at 14:40 #58457beotex
BRONZE MemberThanks, didn’t realize the WISA versions were a mismatch. Especially strange when it shows connected, appears as Beolab 8 in the speaker connections as Wireless PL, and plays the “noise”. Maybe more so disappointing that a fairly recent (and very expensive) TV is incompatible.
Still working on the cable connection – ordered new shielded cables to see if that makes any difference. Right now, I get bad noise/ feedback but no actual sound from the TV.
My B&O Icons:23 August 2024 at 18:10 #58585beotex
BRONZE MemberChanged cables to CAT8 shielded and reset the speakers, and now they work with the TV.
Now, to figure out where to put them since I hadn’t planned on having to hard wire them…
My B&O Icons:12 May 2025 at 17:39 #65552beotex
BRONZE MemberHi
So, still not giving up on this, and saw this posted on B&O support page (https://support.bang-olufsen.com/hc/en-us/articles/19039779370001-Can-Beolab-8-be-used-in-a-surround-sound-setup-with-a-Beovision-TV). It states that the BL8 should work wirelessly with the Avant NG. Anyone have any luck?
My B&O Icons: -
