Home › Forums › Product Discussion & Questions › BeoRemote › Which remotes have Phono button?
- This topic has 7 replies, 5 voices, and was last updated 10 months, 3 weeks ago by
Madskp.
23 November 2024 at 09:21 #61100
CharlieWednesdayGOLD MemberQuick question – which of the later remotes still have Phono available as a source to select? I have a Beo4 Mk41 and a Mk4. I can select Phono (via the List button) on my Mk1 but not on my Mk4 – I have to use N.Radio instead. That works, but it’s annoying!
So, I was thinking of getting either a Beo4 Mk2, Beo4 Mk3, or Beo5 for that room, but I am not sure which versions have a Phono button available – can anyone tell me?
23 November 2024 at 11:06 #61101 GuyModeratorOf the Beo4s, I think you are safer to go for the Mk1 ‘AV’ version to get PHONO. In my notes I have written that PHONO may have only been available in LIST prior to Beo4 SW 4.2, but I am not at all sure if this is correct!
There may be a Beo4 SW version that will show both PHONO and N.RADIO – possibly one of the early Mk2s (SAT, DVD version) that was introduced in the early days of N.RADIO.
Not sure about Beo5/6. (EDIT: I just checked by running the Beo 5/6 configuration tool and it does allow you to chose PHONO as a source displayed on the screen – I combined it with BC9500 in this instance. I haven;t checked with a physical Beo5/6))
But have you considered BL1000 which has PHONO written on the physical button? Or even Beolink Audio Terminal?
23 November 2024 at 11:25 #61103 carolpaBRONZE MemberBeoremote One (non BT): Rename N.Radio in Phono
23 November 2024 at 13:53 #61109 CharlieWednesdayGOLD MemberThanks both. I already have a Beolink 1000 but that’s in use in another room.
In this room, I also have a Beovision 7, and while a Beolink 1000 will control a BV7, a Beo4 is much better for that. That’s why I’m thinking of another Beo4, or I might get my first Beo5.
I’ll see if I can get a Beo4 Mk1 or Mk2, or maybe a Beo5, as your test @Guy seems to tell me that this would work. I may be coming back to you for help with the Beo5 configuration tool if I manage to get hold of one though!
25 January 2025 at 16:20 #63078 GuyModeratorThere may be a Beo4 SW version that will show both PHONO and N.RADIO – possibly one of the early Mk2s (SAT, DVD version) that was introduced in the early days of N.RADIO.
I am quoting myself from a while back, however I just realised that the Beo4 that I am fixing has both PHONO and N.RADIO (i.e same IR command with two names) available to be added to the LIST button – it’s a Mk2 SAT, DVD version at EE: 6.0 and SW:5.00
(Not relevant to this thread but on a similar note, it also has both A.TAPE2 and N.MUSIC available to be added to LIST.)
26 January 2025 at 10:14 #63093 matadorModeratorBeolink 5000.
11 May 2025 at 12:45 #65528 CharlieWednesdayGOLD MemberUpdate – since posting this question I have discovered that the Beo4 Mk1 and Mk2 both seem to have PHONO available as a List button you can add. The Mk3 and Mk4 do not.
It may be dependent on the software version, but I currently have one each of Mk1, 2, 3 and 4, and that’s what I’ve found on these.
12 May 2025 at 09:48 #65539Madskp
GOLD MemberA little down this page https://www.hifi4all.dk/forum/forum_posts.asp?TID=78664&KW=Peter+Pan&PN=0&TPN=1 is a (not complete) list of software revisions for BEO4. Some of the text is in Danish, but hope it can be usefull.
Th list indicates that the N.music/N.Radio functions must have been added in SW 4.2.
