Home › Forums › Product Discussion & Questions › BeoGram › Which Beogram turntable
- This topic has 11 replies, 5 voices, and was last updated 3 years, 6 months ago by
mexking.
5 September 2022 at 07:34 #38862
Sia43
BRONZE MemberAlthough I have owned B&O products since 1986, I’ve never owned a Beogram turntable and back in the days, my partner’s old Yamaha made do.
I still have a few vinyl recordings left (simply couldn’t let them go all these years) and was thinking that perhaps it is time to put them back in work and actually listen to full albums instead of jumping back and forth in playlists.
I simply thinking of getting a Beogram and connecting it to a combined NL/ML network, using an Essence MKII, so here are my questions?
1- Which of The Beograms can be controlled with Beoremote one BT, Essence or Halo?
2- Which one of the candidates from question 1 are the best you can get for money in terms of reliability and functions (in that order)?Thanks
5 September 2022 at 20:12 #38863 chartzBRONZE MemberNone can be remote controlled by B&O modern equipment. Try to find a nice mint Beogram 1700 of 5000. But you’ll need a phono preamp.
5 September 2022 at 20:27 #38864Sia43
BRONZE MemberThanks Chartz, but I believe Steve from Sounds heavenly Talks about one in a youtube clip. See blow link
5 September 2022 at 21:48 #38865 MillemisBRONZE MemberYou will need a Beogram with datalink connection.
If you want to be able to control and use it with the newer stuff (Essence MK2….), you will also need an audiomaster/Beocenter, that can connect to the NL/ML Converter via Masterlink.
This is how the do it in the Beo Home (in the video from Steve).
Here – in addition – it can also be accessed via voice control….MM
5 September 2022 at 23:31 #38866Sia43
BRONZE MemberThanks again, MM, for the highly valued advice.
So do you mean that:
1- A Beogrma cannot be connected directly to a BS-Essence.
2- Or do you mean it can be connected to BS-Essence while controlling it remotely requires an audio master in the ML network?
3- If the answer to 2 is Yes, would any ML-enabled audio master do, such as Beocentre 2 or Beosound 4?
4- And finally, which Beogram is the most recommended turntable?
Thanks again
6 September 2022 at 09:06 #38867 MillemisBRONZE Member1: Yes, it can….but you will not be able to (remote) control it……that was what you asked for in your initial posting.
2: Yes, otherweise you won’t be able to utilize the needed datalink connection (that it where the controlling happens).
3: Yes, and furthermore any older master (e.g. a BM4500/6500….) that is connected to the ML chain using a 1611 Beolink Converter.
4: Hard to say – but you are limited to one with datalink (e.g. a 4500, 6500….), if it should be controlable via the NL devices.
Honestly – the easiest way would be to connect a turntable of your choice (you might need a riaa amp) to the line-in of a M3 or an additional Essence MK2 without connected speakers – this way it will be accessable in the NL chain……
….…you will need to place the vinyl disc physically on the turntable and turn it over after 20 minutes anyway ?
6 September 2022 at 11:18 #38868Sia43
BRONZE MemberDear MM,
Thanks once again. As always, you have been truly helpful, which I’m grateful for.
6 September 2022 at 16:33 #38869 chartzBRONZE MemberI agree: don’t bother and just enjoy pressing the start button of a nice 1700 or 5000. Or of course a 4000…
6 September 2022 at 17:12 #38870 GuyModeratorI would hold out for a ‘remote controllable’ solution; there’s something special about being able to control a ‘mechanical’ device by remote, especially if it’s a Beogram ?
6 September 2022 at 17:16 #38871 chartzBRONZE MemberTrue. The Beolab 8000 and the pizza boxes are a joy to use and behold.
6 September 2022 at 17:22 #38872 MillemisBRONZE MemberAgree with Guy and chartz.
However, since Sia43 wrote in the initial posting:
“I still have a few vinyl recordings left”,
I thought that I would offer him the more uncomplicated (and also cheaper) way of doing this….in addition to the ‘real thing’.
7 September 2022 at 19:00 #38873 mexkingBRONZE MemberI have restored various BGs from BG 1000 to BG 4002 and BG 5000. From a mechanical point of view I recommend the BG 5000, I bought that one 12 years ago, opened it up and cleaned and lubricated it, checked all adjustment and it has been my daily used BG nearly ever since. IMO the best build BG I have come across, build like a tractor. I use a MMC 2 on it. The difference to a MMC 4 is clearly hear able. Its the only BG I have had that I could store for a couple of years, take it out. connect it and run it without any problems.
