Home › Forums › Product Discussion & Questions › BeoGram › Which beogram for beocenter 9300
- This topic has 2 replies, 3 voices, and was last updated 2 years, 12 months ago by
yachadm.
22 March 2023 at 09:25 #44890
duenoGOLD Memberhi,
Which Beogradm is best for beocenter 9300 (Beogram 4500, 9500, …..).
Thanks.
23 March 2023 at 08:11 #44891 GuyModeratorThe BC9300 does not have an internal RIAA pre-amp, hence you need to get a Beogram with RIAA such as the Beogram 3500, 4500, 6500 and 7000, which all have RIAAs fitted as standard. The Beogram 9500 will not work unless you add a separate external RIAA pre-amp, which then complicates the ability to remote control the deck because the datalink will need to be connected separately.
See this link: https://www.beoworld.org/faq_view.asp?id=18
And the following thread suggests the BG4500 for the best visual match:
https://archivedforum2.beoworld.org/forums/p/35701/265112.aspx#265112
28 March 2023 at 11:59 #44892yachadm
BRONZE MemberHere’s a solution from another enterprising small workshop in Denmark.
RIAA amplifiers to fit different BeoGram models:
https://claudius-elektronik.dk/designs-og-l-sninger.html
