Home Forums General Discussion & Questions General Discussion & Questions Upgrading a Beogram TX-2 to Beogram 7000 specification
Viewing 19 posts - 1 through 19 (of 19 total)
  • #72440
    TK
    I’ve found many posts over the years where folks have discussed what can be done to improve the TX-2 (which is generally the cheapest of the bunch), but no real hands-on guide.  So when an inexpensive TX-2 popped up on eBay, I decided that I’d make a bid for it, with the plan of putting one together.
    It arrived today, so I set off by giving it a spit-shine, and testing basic function.  It’s a suitable candidate for a refreshtoration, so off I go.  I’ve got 3 main objectives: 1) Refresh the board, and add the Datalink transistor; 2) Replace the output wire with a Din-7 plug; 3) Create an inexpensive RIAA board, and upload the design to PCB Way to produce (Perhaps there is a forum member who would be willing to share their existing files).
    #72442
    TK
    First things first – does the TX-2, in fact, ship with Datalink enabled?
    Early answer: yes, it appears so. But more testing is required to verify the entire instruction set.
    I’ve been postulating on this for the past month, trying to find a definitive “it does” or “yes, but there’s a catch…” post, but I figured I’d have to do my own testing anyways.  So before changing out the RCA output cable, I thought I’d run a quickee test of the Datalink channel on the main board, to see what signals were being sent, if any.  I attached a signal analyzer to the board output (going from CPU pin 19 through some circuitry to pin 1 of the white connector) and measured the results.  Presto: Datalink. I received both a “No Media” signal and a “Status Playing” signal, depending on whether I held the record sensor down. With this experiment done, I’m quite confident I’ll be able to attach a Din-7 cable to the output board, and use the Datalink features on a Beomaster 5500, at least.  For the later units, I’ll still need to find or create an RIAA card.
    #72446
    adyan
    Hello again,
    as already answered here I have done this with my TX2. I have PCB´s of my RIAA left, if you like to get one send a private message.
    Details:
    https://forum.beoworld.org/forums/topic/beograd-59xx-riaa/
    #75706
    TK
    I’ve had the opportunity to tinker around a bit with a few TX-2 / 5500 PCBs – I used to think that they are nearly identical across the various iterations of Beograms from the 3000 to the 9500, but it turns out there were additional  subtle improvements, as one might expect with the introductions of several models.  I’ve outlined some of the changes that I can spot – perhaps there are more changes that others know of.
    Here’s an example of an early 5005/TX-2 board:
    A 5500 board looks like this below.  It adds a Transistor TR11, whose stated function is to keep the Datalink network working even when power is cut to the turntable.  Early 5005 boards did not have this transistor, and B&O must have discovered that Datalink stops working if the 5005’s power is cut, driving the CPU I/O low:
    The last board I have for comparison is a late board from a TX-2, which has all the modifications used in the 7000 that I am aware of.  In addition to the TR11 (which is only used for the 6500/7000), it also has a new microprocessor with a dedicated pin running to the front-facing “play” button. I’m taking this to mean that the outside button is now meant to function as an “play/off” switch, as opposed to a “play/repeat” switch:
    With respect to the differences, it’s a fairly straightforward procedure to add the TR11 transistor, which I’ll do for this upcoming specification upgrade.  This also serves to decouple the CPU from having direct exposure to the Datalink pin, hopefully giving the CPU a bit of protection from problematic external hookups.  There’s not a whole lot I can do about implementing the “Play/standby” function vs the “Play/repeat” function, as I want to use the late board I have (the one with all the upgrades) in a 5500 upgrade instead of a TX-2.  More on that upgrade in a little while.  For now, I’m going to add the TR11 upgrade, and call it good enough.  I’ve found a few other improvements (mostly to support the addition of RIAA) which I’ll detail in a subsequent post.
    #75784
    TK
    With the Beogram power supply, the story is much the same as the main PCB –  the supplies all have the same basic capability across models, but depending on the model and region, the way they were wired varies slightly.  With the deployment of an On-board RIAA of the 6500, it became necessary to power the IRAA via two power feeds from the PS. This necessitated the inclusion of a small 2-wire pin to the PCB, from where the RIAA could be powered
    Of the US-based TX-2 that I’ve seen, it appears that both early and late examples utilized the power supply setup as seen below, irrespective of which generation main PCB was installed.  This supply was wired for 120V, with a large fuse taking up much of the PCB #2 real estate, and no support for an RIAA hookup:
    Later Euro TX-2 examples appear to have the 2-pin RIAA hookup, as shown here (photo 1 supplied by adyan, who has extensive knowledge on RIAA for these systems, and has supplied me with a pair of boards for this upgrade)
    Here is a picture of a BG 6500 PS, which resembles the example that adyan has in his late TX-2, and also has the 2-pin power hookup.:
    These 2-pin RIAA hookups draw from power points which are readily accessible from any of the TX-2/5500 ps, but it does require a bit of retrofit work to tap into them.  My plan is to solder a plug onto the board that will allow access to the same power that the boards with built-in RIAA hookups have.  On the board below, soldering a hookup to the bus leading to pins labelled 1 and 3 (center of board) of the IC I/O will give the needed result of having a 22V and 12V supply, respectively.
    #76041
    TK
    Here’s a “Old vs. New” 59XX schematic connecting the CPU to the Datalink bus.  The new schematic includes a 547 transistor and 10K resistor hardwired to 5V, so it will be active as soon as the Beogram is plugged into power.
    OLD SCHEMATIC
    NEW SCHEMATIC
    It turned out to be a fairly straightforward process adding a transistor to PCB1. I took a 547 equivalent transistor, and soldered a 10K resistor to the B pin, and added a bit of heat shrink to prevent a short.  Next, I repositioned R42 by removing the Datalink bus leg from the board, and soldering it to the C pin of TR11.  Last, I placed the TR11 E pin into the now-empty hole which previously connected R42 to the Datalink bus, completing the circuit.  I contemplated drilling holes in the board and routing the wire underneath the board, but in the end my eventual solution was much simpler to execute, and I think it turned out looking OK – the parts are basically in the same spot they would appear in a later board, so it will be simple enough to understand what the retrofit’s purpose is. This is a picture from a 5005 board I had retrofitted earlier:
    #76047
    TK
    Next step is adding a power plug for the RIAA amps I purchased from adyan.  His design mimics the original RIAA boards used in the 6500-7000 models, and therefore also needs a 22V and 12V supply, which it gets from the transformer on a plug from PCB2.  None of my US-Spec TX2 transformers – early or late models – have this 2-pin plug, so I had to tap into the PCB at the correct spots.  Here again I contemplated drilling PCB2 to add a surface-mount plug. And once again, for simplicity I opted to add a pre-wired 2-pin connector instead.  I attached the red wire lead to the existing 12V wire hookup (post IC), and the black wire lead to the 25V output from the rectifier. This way, Red would consistently be the 12V supply.   The plugs are male/female, so there’s no way anyone could accidentally feed a 25V input to PCB1 ground by mistakingly hooking up the incorrect plug.
    With these straightforward updates completed, I’m ready to tackle installing the RIAA board.  I’ve opted to upgrade my 5500 and TX-2 simultaneously, in order to teach myself a bit about both upgrade paths.
    #77359
    TK
    I decided I’d upgrade the 5500 first, on the thought that the wiring would be a bit easier.  This proved to not be the case – B&O supplied the original output cable with an extra unattached blue wire, which was not connected to pin 7.  I made the decision to disassemble the Din connector to attach it.  This is strictly not necessary for my planned use, but I wanted to observe the convention that “Beograms with RIAA run Datalink on Pin 7”.
    Upon disassembly, I found that not only was the blue wire not attached, it was truncated to the point where I’d have to un-solder all the pins and re-cut them to the new length.  This is fiddly work which I’m personally not terribly fond of.  I just happen to appreciate the coolness of a removable pin 6 and 7, and want to preserve that feature. I wired up both pin 6 and 7 with the blue and yellow wire.  Without thinking about it first, I moved the yellow wire to pin 7, and soldered the blue wire to pin 6.  Inside the turntable I’ll have the blue wire available on pin 6 for a future new project I’m dreaming about.
    After a bit of squinting, cursing, and double checking my work for shorts, I was ready to reassemble the connector. Then came the “one-way” step of snipping the cable at a point I thought would provide enough wire on either side of the RIAA card to connect everything together using the original wires.
    #77370
    TK
    On reading, re-reading, and re-re-reading the latest version of the service manual RIAA schematic, I came to the conclusion that the “Old Version” PCB 11 would need a modification in order to electrically emulate the “New Version” mute circuit.  The original PCB11 is wired such that LG and RG from the stylus are not connected to chassis ground or shield ground until the wiring reaches the Beomaster.  Further, the mute circuit is implemented by grounding the L and R to LG.
    New boards designed for dual use as RIAA or non-RIAA implement a sightly different protocol, which necessitates the cutting of a wire bridge between some of the solder pads to achieve the desired circuit.  Also, the LM and RM wires work a bit in “reverse”, where the mute circuit acts to ground the amplified signal on mute activation, before it reaches the output cable.  The only way I could see to mimic this implementation was to grind a cut on the PCB itself, isolating L and R from the original mute circuit. [EDIT – I’ve made a small change to the schematic, and included both versions for comparison]
    Original Version combines L+ R during ‘unmute’ – potentially undesirable:
    Final Version – isolates L&R outputs during ‘unmute’:
    With that mental hurdle cleared, all that remained was to wire PCB11 with a jumper between LG, RG, and chassis ground, which meant that the mute circuit was now also connected to chassis ground.   I considered that LM and RM are really the same signal and could actually just be activated together using a single wire [EDIT – I’m not actually sure this is 100% true in all scenarios, although it did appear to function correctly], but I went ahead and wired a separate LM and RM to the mute switch, per the schematic. [EDIT – even though the Original Version worked as wired, I realized later that I’d connected L+R in a way that might lead to some odd behavior when unmuted, so I moved one of the channels to a new position, where they would be isolated during ‘unmute’.  The original wiring solution didn’t seen to affect the performance of the circuit, but the final version is representative of the original schematic] With L & R inputs reattached in their original spot, I was set to finish wiring up the RIAA.
    Original Version:
    Final version:
    Admittedly sloppy, but it all toned out properly, so I left it as-is, and re-installed PCB11.
    #77374
    TK
    On to the final steps – finish routing the wiring, and connecting the RIAA.  The original wires ended up being just a bit short to wire around the underside of the board as I would have liked, but at this point I didn’t care – I wanted to see if my upgrade had worked!
    With the wiring complete, I re-calibrated the board based on the service manual (recall, I had swapped out the original 5500 board with a later board that had a discrete “Play/Off” feature, like the Beogram 7000).
    Moment of truth! Triple check to make sure everything was as-planned, and hook it up to my Beomaster 7000.  Everything worked as expected –  Lovely! Special thanks to @adyan for making a few RIAA boards for this project.  I have no doubt the TX-2 will work as well, but I’ll go through the steps to document the process.
    #77399
    adyan
    Congratulation, glad that everything worked out and have a nice time listening to your upgraded beogram.
    #79394
    TK
    I took delivery of another late-model PCB1 control board (with the discreet Play/Off hookup), so I decided to replace PCB1 on my 5005, and do a bit more analysis of this late-model feature.
    This additional feature basically provides continuity over the component range, as compared to the earlier Beograms where the button was a mere extension of the “Play/Repeat” button located inside of the cover.  The original Datalink status sent by the original Beogram 5005 thru 5500 was “Play/Repeat” is a single Datalink command “Beogram.Status.Playing” when first pressed.  Subsequent presses of the “Play” button put the Beogram in ‘Repeat’ mode, and were handled without sending any additional information back to the Beomaster. In fact, this was a missed opportunity by B&O to send a ‘Status.Counter’ to update to the MCP on any ‘Status’ request, showing the number of queued repeats – for example, the Beogram could easily have been coded to send “Beogram.Status.Counter ‘C 03’ “, reporting back to the MCP screen the number of record plays remaining – a trivial code addition which could have provided some visual feedback to the listener as to the number of repeats remaining.
    Conversely on the late PCB1 board, the pressing of the front button while the Beogram is playing sends two Datalink commands: “Beogram.Status.Standby”, followed a few seconds later by “Beogram.Status.Stopped” when the platter stops spinning.  Sending the Standby command will cause the Beomaster to act accordingly.
    If I ever find the time to create a replacement microcontroller for the Beogram, I’d like to add a feature-set which provides more status reporting to the listener.  Repeats, song count (based on 3 seconds of silence, for example), 33/45 selection via the MCP, and things of this nature would make excellent upgrades to the base system.
    #79399
    TK
    Just to document the needed changes to add discreet “Play/Off” function to an early Beogram, these are the steps.
    The “Play” button is fixed in place with a black bracket, which holds the button in the appropriate place on the front panel.
    It’s wired directly to the “Play” button on the top surface, so it only can perform the same function as the “Play” button under the cover.  The large PCB3 is removed by carefully moving the 4 black tabs that hold it firmly in place, and wiggling the PCB up and back out of its mount.
    I was surprised to see that these buttons were exposed – typically, they are covered with black tape to help hold them in place (and probably also to keep moisture and debris out from them – they are a slightly cheap design, and can easily be made inoperable with a bit of contaminant).  I fixed the vulnerability by adding a bit of electricians tape myself.  Next, I severed the connections of the small PCB, and added two additional wires to it, per the new design specification.
    Last, I ran these new wires back through the cover, using the same clamps used for the existing wires.  A bit of trimming later, and everything was hooked up per the late-model specifications.  A fairly straightforward modification.
    I’ve elected to not add an RIAA to this unit, as I need something I can use to test with earlier variants of Beomasters with built-in RIAA.  So this unit is upgraded as much as it can be, and ready for work.
    #123464
    TK
    I’m restoring another 5005, and I elected to try another technique for retrofitting a TR11 BC547 transistor into the datalink path of PCB1.
    I started with a new BC547 transistor I bought from Mouser.  When looking at the flat face, the pins from left to right arre (C) Collector (B) Base and (E) Emitter.
    I unsoldered R42 on the side nearest the I/O cable, and drilled a small hole 2-3cm from it, taking care not to pierce any existing traces, or the adjacent R45 resistor.
    Next, I took the BC547 and placed the (C) pin through the vacant R42 hole, and the (B) pin through the newly drilled hole.  I bent the (E) pin towards the R42 resistor.
    Turning the board over, I unsoldered the jumper adjacent to R30, and squeezed a 10K resistor through the hole.  Theere was just enough room to have both the resistor and jumper in the same hole, which I resoldered in order to make a permanent connection.
    I covered the resistor lead with heat shrink, and soldered the end to the (E) pin of TR11. This heat shrink is just a security blanket to prevent future shorts on the board.
    I finished with attaching the TR11 (E) pin to the R42 resistor, and covered the end with a piece of heat shrink.  IMHO, this looks much nicer than the other solution.
    #123493
    Hiort
    GOLD Member
    Impressive work I must say 😊
    Im sorry I was not paying attention in my electronics class in school 😏
    TK
    Another day, another upgrade.  This time I’m taking a Beogram 3000 and upgrading it to Beogram 4500 specification.  I got this unit because I thought it would fit in stylistically better with the black 7000 series that I have. My first thought was to simply replace the 5500 shell with the 3000 shell, but I decided to leave well enough alone – the 5500 had the latest motherboard with the discrete standby function, which the 3000/4500 could not  make use of, because it lacks a front face.
    I started with the chassis.  Some new feet and touch-up paint to cover up the deep scratches.
    I’m using graphite-infused black paint, in order to keep all areas of the base conductive.  It’s not a perfect match, but IMHO better than exposed bare metal. My hope was to eventually use this conductive paint as a new semi-black coating for the platter, but that will be a bit later when I’ve experimented a bit with it.
    • This reply was modified 1 month ago by TK.
    #123690
    TK
    This go-around, I thought I’d take a stab at creating a plug for the RIAA right on PCB2, like the original.  After checking all the caps and diodes for function, I drilled 2 small holes with a 1.0mm bit using a hand drill. It’s a tight squeeze on a US-Spec power supply, due to the long fuse which occupies the space normally reserved for the plug. Thankfully theres an adequate space over the PCB label, where there are no traces to damage.
    I added a dab of crazy glue to the backside of the plug, and placed it in the hole. So far, so good!
    The rear side required 2 wires.  I decided to stick to my convention of keeping the red wire at 12V, and the black wire at 25V.
    After checking all connections for connectivity and shorts, I was ready to insert the power supply back into the chassis. I replaced the regulator IC for good measure, as the installed one was reading 11.7 volts – it probably would have worked fine, but the new one was bang-on 12V. Although I have a few NOS barrel capacitors, I elected to keep the original in place, as it was reading a healthy 1100uF / 0.47 ISR, with no signs of leaking.  Another step complete.
    #123708
    TK
    I also came up with a better version of the motherboard upgrade for early 5005 and TX-2 boards to prepare them for Datalink use, by placing the 10K resistor in the same location that it appears on the 5500 and newer boards.
    I first drilled a hole for the resistor.
    Next, I placed the resistor and transistor in their proper locations, taking care to leave the legs long, so I could connect them later under the board. I didn’t make any changes to the transistor placement from the last iteration.
    Last, I connected the legs of the resistor and the transistor base, followed by a protective heat shrink cover to prevent shorting.
    • This reply was modified 4 weeks ago by TK.
    #124082
    TK
    Here’s a solution that no one really was asking a question about. The tiny tab that holds the thread ends which move the tone arm sled tends to snap when things bind up.  This morning I took a stab at a remedy.
    For starters, the bottom of the sled appears to contain an extra tab that does not appear to be used for anything, so my first thought was to carefully slice this off and find a way to graft it in place of the missing one.
    I decided to forego that option, and opted instead to head to the hardware store to purchase a few 1.6mm bolts with nuts. This would provide a bit more holding surface and friction. The idea is to place the string and spring in place, and thread the nut onto the rod as a “keeper”, which would prevent the string from falling off.  This new plan of action involved generously epoxying over the holes, and drilling a pilot hole I could thread with the bolt, which I thought would be stiff enough to provide a robust holding point to the thread.  Alas, laziness prevailed- I went with super glue, and simply positioned the bolts during the curing phase.
    We’ll see if this provides enough durability to create a lasting solution to the problem.
