Home › Forums › Product Discussion & Questions › BeoLab › Updating WISA firmware Transmitter 1 / Beolab 17
- This topic has 5 replies, 5 voices, and was last updated 2 years, 6 months ago by
NQVHNWI.
13 December 2022 at 06:56 #41405
LeMirage
BRONZE MemberAnyone flashed firmware of Beolab Transmitter 1 ?
I recently bought a ex store demo pair of 17’s and a Transmitter 1 . The 17’s came from a dealer and probably not really old stock. The Transmitter 1 was from ebay and hard to determine it’s age.
According filenames and dates from the update software (to download from B&O support site on a USB flashdrive first) latest Wisa firmware for 17’s dates already back to 2018.Last Firmware from Transmitter 1 is from 2020.
Amyway, followed all the instructions on B&O support site for the update process but all the described sequences of flashing LED’s on not Transmitter 1 and Beolab 17 are not observed, with the USB flashdrive inserted in Transmitter 1 , it just does it’s normal boot sequence as well do the 17’s.
I think this means both Transmitter 1 and 17’s both have latest firmware onboard, but there is no way to verify that!!
Don’t have any complaints by the way, Core is powerlinked to Transmitter 1 wireless feeding the 17’s and the connection is just rock solid. No hickups, delay, weird noises, it just works. Did not expect that to be honest 🙂
Anyone experience with this process?
14 December 2022 at 11:54 #41406beojeff
BRONZE MemberThere is a file on the USB thumbdrive that logs the activity. You can see if the speaker was skipped or updated and what the firmware of the speaker/receiver is. I saw a different behavior for Receiver 1 units that were being updated compared to ones that already had the recent firmware. I found it to be good practice to have just one speaker/receiver plugged into power at a time for the firmware update cycle so that I could see what was happening for that specific Receiver 1.
15 December 2022 at 06:27 #41407Losser12
BRONZE Memberhello
your issue is not doubtable ,
might be my answer helps you
To make a software update of your Beolab 18 via Beolab Transmitter 1, The product status indicator flashes green during the software update.
15 December 2022 at 20:19 #41408LeMirage
BRONZE MemberI will give it another try during the weekend. Thanks all.
12 September 2023 at 10:27 #41409pinliver
BRONZE MemberI wonder if you have done it successfully?
12 September 2023 at 11:12 #41410
NQVHNWIBRONZE MemberSo I did very similar to you – buy a used pair of BL17s from a B&O Dealer. Requested that the BL17s were flashed to the latest software before dispatch. (so i didn’t have to buy a BeoTrans1).
- How can I tell if they were really flashed to the latest SW? No proof?
- What difference did it make? Don’t know…cant compare.
- What was in the SW update? I heard anecdotally it was for WISA improvements only….no change to the Sound and as I’m wired configuration only…….
