Home Forums Product Discussion & Questions BeoLink Universal Link Adapter
Viewing 10 posts - 61 through 70 (of 70 total)
  • #49611
    B3OHACK3R
      But also very interesting if it actually is possible to send such things as datalink commands. @B3OHACK3R do you have some kind of overview of what actually is possible to do with datalink commands besides the obvies like play/pause, stop, standby, fw/rw and so on?
      Obviously you can do everything that is also possible in an option 2:0 setup with a (2-way) video master.
      What I currently don’t exactly know is if it’s possible to send local control commands like volume, treble, bass etc. via datalink in an option 1 setup. Haven’t looked into that yet.
      #49612
      Madskp
      GOLD Member
        That makes sense. A beomaster/beocenter in option 0 should be able to get all remote commands from a connected tv in option 2 via datalink
        Yes thats interesting if the Beomaster/Beocenter does not react to all commands on datalink if it is in option 1
        #49613
        Guy
          But does it get (or even need) volume control commands when the only audio output from the Beomaster/beocenter is usually at a fixed line level? In that option 2:0 setup does the Beomaster/beocenter volume display change when you adjust volume via the TV – I can’t remember from my previous setup!
          Also, if using a Beolink Converter 1611 as part of an option 2:0 setup, you need to add a Powerlink cable (Beomaster/beocenter to 1611) to ensure that volume changes on the Beomaster/beocenter front panel are conveyed to adjust the volume output from the TV.
          My B&O Icons: BeoCenter-9500 Beo4 Beovision-10BeotimeBeosoundBeosound-Explore Beosound-Essence Beoplay-P2Beoplay-M3Beoplay-H4Beoplay-H3Beoplay-Form-2iBeoplay-EarsetBeoplay-A2
          #49614
          B3OHACK3R
            If the music system is in option 0 and you request a source through datalink it will start up in “muted” state. In that case volume commands are not transmitted through DL as this usually happens in the option 2 master device.
            Volume on the DL / ML port is always at fixed level.
            On the 1611 PL socket only pin 4 is used. Likely as a wake up signal. No PL data signals are used in the 1611.
            Regarding that volume issue was more thinking of a stand-alone scenario where you are using the AAL port to feed an external source into the music system. Then you would have to deal with two independent volume controls – unless you could send a certain local volume command via DL before playback starts.
            #49615
            Madskp
            GOLD Member
              Just got me thinking of this thread https://forum.beoworld.org/forums/topic/beolink-passive-ir-eye/page/3/#post-20843 where I tested an MCL IR eye connected to the AUX connector of a Beomaster 5500 and was able to control it via the IR eye. So based on that volume control via datalink should be possible. I don’t have the Beomaster 5500 anymore, but can try to do the test with a Beocenter 9300 and Beomaster 4500 and see if it works the same.
              #49616
              B3OHACK3R
                Ah, thanks. That is some good input again.
                I made the assumption that local volume control through the AAL / DL port should be possible because I saw that the IR protocol is very similar to the DL one. I would have tested it by just sending a Beo 4 IR command for volume up/down without the carrier enabled.
                Perfect that you already tested that! So most likely they are even identical.
                #49617
                Madskp
                GOLD Member
                  Madskp wrote: Just got me thinking of this thread https://forum.beoworld.org/forums/topic/beolink-passive-ir-eye/page/3/#post-20843 where I tested an MCL IR eye connected to the AUX connector of a Beomaster 5500 and was able to control it via the IR eye. So based on that volume control via datalink should be possible. I don’t have the Beomaster 5500 anymore, but can try to do the test with a Beocenter 9300 and Beomaster 4500 and see if it works the same. Ah, thanks. That is some good input again. I made the assumption that local volume control through the AAL / DL port should be possible because I saw that the IR protocol is very similar to the DL one. I would have tested it by just sending a Beo 4 IR command for volume up/down without the carrier enabled. Perfect that you already tested that! So most likely they are even identical.
                  One sidenote to this, I don’t know if it applies to all Beomasters/Beocenters. For the Beomaster 5500 I noticed that the datalines for the MCL2 /speakerlink sockets was directly connected to pin 6 on the AUX socket, but for other systems that is not always the case. The functionality could be the same though.
                  #49618
                  M00NMAN
                    Hi, I have a Beogram 8002 connected to my BeoSound Stage. I have a Beoremote One and trying to figure out if I can control the Beogram 8002 with my Beoremote One.
                    I am thinking this Universal Link Adapter might may accomplish that? I have been searching for years for a viable solution.
                    Thanks!
                    #49619
                    B3OHACK3R
                      the Universal Link Adapter was just a proof-of-concept prototype. It is not for sale.
                      Instead a simplified version was developed. Have a look here: https://forum.beoworld.org/forums/topic/masterlink-usb-adapter/
                      Having that said – yes, technically it is possible controlling the 8002 with a BR1. Been doing something similar with a Halo and a BG 5500. It all depends how much you’d like to dive into that topic on the software level as it is not a plug-n-play product.
                      #59640
                      Mikkel Pedersen
                        Hello.
                        I don’t know if it’s a shot in the dark, but I’ll try anyway. I am working on a small hobby project where I would like to be able to control my beogram 5500 via a home assistant. I came across this post and could see you had worked with exactly Datalink 80 and 86 and wanted to know if you could maybe help me a little in my project? I’m not that familiar with writing code, but I’m very curious. I imagine using an Ardunio Uno WiFi Rev2 to read or write data to my beogram 5500. I get the sound out another way – via a Beosound core so I can get it out on the Beolink mulitroom. I would like to be able to control the following; Play and stop on my beogram 5500, do you think it will be possible?
                        Hope to hear from you if this might be of interest! 🙂
                        Kind regards
                        Michael Pedersen
                        Denmark
