Home › Forums › Product Discussion & Questions › BeoLab › Undo sound calibration on Beolab 50?
- This topic has 10 replies, 6 voices, and was last updated 2 years, 9 months ago by
MaxH.
5 May 2023 at 05:49 #46337
MarioA
BRONZE MemberHello, I’m totally new to these speakers and I’m still learning. These speakers were sound-calibrated by the installer. However, I’d rather listen to them for a while without calibration whatsoever. Is it possible to undo the calibration and listen to them without it?
thank you for reading this.5 May 2023 at 21:39 #46338 MillemisBRONZE MemberPlease have a look here 4.2.3.
5 May 2023 at 22:20 #46339NQVHNWI
BRONZE MemberOr…you can load the BeoApp, do a factory reset or cancel/delete the calibrations. It will be similar to this chain of commands on the BeoApp:-
Select Product >> Product setting >> Configure >> Preset >> Select a preset >> Room Compensation >> Select model >> Delete.
Im not sure why you would want to do that as it add so much to the performance of the loudspeaker.
6 May 2023 at 03:10 #46340kawo
MemberThis can be helpful if you would like to measure the acoustic response of the room without the adjustments of the speakers room compensation. I had a acoustic engineer at my house and we measured both, with and without B&O room compensation. Quite intersting by the way. Helped to understand the room and how to tweak the EQ on top of the room compensation to get the max out of the speakers. But of course, this is not the usual use case…
7 May 2023 at 17:51 #46341MarioA
BRONZE MemberThank you so much for the precious info.
Beside the fact that my curiosity leads me to wanting to know what they sound like without it, the calibration performed by the installer was less that optimal to say the least. He was holding the mic with his hand throughout the entire process, and with his body standing between or near the mic as he was handling it. I know I can do a better job than that when I’ll get my hands on the microphone which I don’t have as now. Thanks again.
8 May 2023 at 13:27 #46342 yossiBRONZE Member8 May 2023 at 13:34 #46343 yossiBRONZE MemberMy BL50 sound far far more better with Room Eq
(my room is treated with GIK free standing bass traps and my source is Wattson Madison streamer DAC / rca )
Edit : I am sorry I just wrote the contrary of my thoughts, of course ROOM compensation help a lot but it’s icing on the cake after a good (perfect?) speaker placement and a room passive treatment
10 May 2023 at 01:03 #46344MarioA
BRONZE MemberOk… I did indeed reset ? the room calibration and I regret it already. For some reasons the volume is not as high as it was, despite it is set to max-90, and the tweeter assembly does not recess as It did earlier in just one minute. I’m confused thou: Is there a section with advanced settings as, starting a new calibration? Or set the timer for the standby? Am I missing a portion of advanced software?
I’d love more enlightening.Thank you again for reading this.
10 May 2023 at 08:48 #46345 MaxHBRONZE MemberFirst, you will need a USB microphone.
Read the manual: https://bangolufsenassistentgohe.blob.core.windows.net/manuals/SPEAKERS/BEOLAB_50/beolab_50_technical_sound_guide.pdf#page14
Then watch: https://www.tonmeister.ca/wordpress/2017/04/19/bo-tech-beolab-90-how-to-set-up-active-room-calibration/
Although this video is for the 90s, the process is the same.
10 May 2023 at 13:22 #46346MarioA
BRONZE MemberOk. I panicked for a few moments there… I’ll start with printing the manual. Thank you so much, I appreciated it.
10 May 2023 at 14:00 #46347 MaxHBRONZE MemberAnd I thought I was impatient 😉
If they have been factory reset that’s the ‘normal’ sound without calibration.
Get an appropriate mic, watch the video and notice the mic positions and (personally) I would set up only two or three standard positions at first. One for Narrow, music listening, and one for Wide TV watching, others dependent on room layout.
You don’t sound like a ‘switch it on and leave it’ type of person so once you are familiar with the process, my guess is you may want to experiment with adjusting the positioning of the 50s and ( to my ears anyway) speakers and associated equipment do change sound over time especially if furniture and furnishings are changed.
Good luck. They are exceptional speakers.
