Home › Forums › General Discussion & Questions › General Discussion & Questions › Theatre failure. Help needed.
  • #126055
    YannChris
    GOLD Member
    Hello Beoworlders,
    While looking at the TV, my Beovision Theatre suddently turned off making a huge crack sound.
    I power-cycled the set but nothing happens. No light on the control panel and the Theatre appears as offline in the B&O app.
    The LG TV works with the LG remote, but does not react to the BR1.
    Is there somewhere a switch to reset the Theatre?
    Thanks by advance,
    Yann.
    multicare
    GOLD Member
    Sounds like you have a power supply failure
    pl212
    SILVER Member
    • This reply was modified 31 minutes ago by pl212.
