Home › Forums › BeoWorld around the world! › Nordic › Tape stuck in deck!
- This topic has 3 replies, 4 voices, and was last updated 2 years, 11 months ago by
redfox.
15 December 2022 at 03:33 #41490
lenhi
BRONZE MemberWhat to do? My beogram 6500 found it liked the tape so much, it refuses to let go of it. I did find good, sound advice in an old forum on how to disassemble the deck, but unfortunately, as I discovered, that operation was just meant to get at the motor, which is not doable as long as the tape sits there.
1 January 2023 at 01:34 #41491 filip_kbh
BRONZE MemberI guess you mean your Beocord 6500. If the drawer will not open, you can gently pull it out. The tape should be possible to lift up from the side closest to you.
1 January 2023 at 15:22 #41492Dillen
ModeratorThe tape can become stuck by partly engaged tapeheads etc., if the mechanism stops mid-cycle.
This typically happens when belts are getting worn, and wheels are slipping.Drawer out, from below, through the tiny holes, see if you can rotate the
left flywheel/capstan by pushing it with a small screwdriver or similar tool.
It should be rotated clockwise (seen from above). One rotation is usually enough to release the mech.
It may be necessary to hold the flywheel using something else – a cottom bud or so – while
shifting to the next push of the screwdriver, because the belt will have an “elastic” effect on the flywheel.Martin
16 April 2023 at 22:17 #41493redfox
BRONZE MemberThat is good advice!
Ki nd regards,
Redfox.
