Home › Forums › Product Discussion & Questions › BeoGram › Tangential Drive Lubrication
- This topic has 3 replies, 3 voices, and was last updated 3 years, 1 month ago by
NQVHNWI.
19 February 2023 at 11:26 #44013
NQVHNWI
BRONZE MemberHi All,
Hopefully diverted an immediate problem with my TT arm dropping too soon and rolling off the LP without bedding into the groove.
Pulled the deck apart and wire-brushed the threaded drive bar. It looks like some residue had built up along the critical length adding resistance to normal play.
After cleaning, all works correctly. however, can anyone tell me if there is a lubricant and lubricant schedule for this drive bar.? I’m currently thinking that a minute drop of a light oil will do the job (hair or beard trimmer oil)?
Can anyone advise? Thank you
20 February 2023 at 15:42 #44014 filip_kbhBRONZE MemberI think perhaps it would be great to specify which Beogram you have. If there is a threaded bar, I am thinking Beogram 4000/2/4. I have used a silicon lube for mine which seems to be working great since lubrication some years ago.
20 February 2023 at 17:00 #44015Dillen
ModeratorA small amount of teflon-based “oil”.
A seller on Ebay once had something called “liquid bearing”, that’s very good.
Because it’s not really an “oil”, but mainly microscopic teflon balls, it doesn’t really
evaporate and it doesn’t grab and hold dust and dirt the same way an oil will.Don’t use shaver- or sewing-machine oil. It evaporates over hours rather than years, and
most will leave some of its additives etc. behind.Forget WD40. Keep that in the garage for use with rusty cars.
21 February 2023 at 11:58 #44016NQVHNWI
BRONZE MemberThanks for the info.
BG8002
Vaseline lube is not on the menu and in the same cupboard as is the WD40.
edit. would add that WD40 do do dry silicone lube?
