Home Forums Product Discussion & Questions BeoSound Stage: double tone when not in use?
  • #44819
    Adamjmoldenhauer
    I just bought the Stage and it was amazing— easily connected to wifi, paired with my Sony tv effortlessly… was great to play music thru my iPhone. Then this week it’s been making intermittent double click/tone sounds when not in use.
    Is there a simple thing I’m doing wrong? It’s not happening constantly but can’t seem to figure out what I’m doing (if anything) to make that happen. I completely close Apple Music on my phone, or turn the TV off, and that seems to be when it’ll make the double-click/tone sound… sometimes once, sometimes every ten minutes
    #44820
    Hiort
    GOLD Member
    This could be “system sound”. Could it be that it connects/reconnects to WiFi of some reason? I think you can disable the “system sound” in the app menu for Stage somewhere.
    Mark
    The two tones, is the first tone higher than the second?  This usually indicates that the unit is turning off.  If the second tone is higher that indicates that the system is turning on.
    What this sounds like is the Stage doesn’t turn off when you stop streaming.  If there is no activity after 10 or 15 minutes (I forget how long) then the Stage turns itself off (standby).  In the B&O app, you can put the Stage in standby or all systems in standby with the power icon at the top left.
    #44822
    Mark
    I believe the “system sound” can be disabled in:
    Product Settings -> Configure -> Settings -> Local Operation
    uncheck Enable notification sounds
    #44823
    Adamjmoldenhauer
    Thanks everyone— I tried Mark’s suggestion and will update here if it continues. So far so good.
    thanks again
