Home Forums Product Discussion & Questions BeoSound Sound delay BS9000 BS2 BL8000
  • #123317
    Isaac Nix
    I have a Beosound 9000 which is connected to a pair of beolab 8000s, I have recently purchased a NL/ML Converted as i wanted to be able to controll it via the b&o app. I have just added a beosound 2 to the set up and it sounds great, however no matter what i try I still get a delay. the audio coming out of the 8000’s and beosound 2 doesn’t sync even with the lowest delay setting in sound sync. Any idea how to fix this? have tried chaning the delay with no luck. Thanks
    #123331
    carolpa
    The simplest solution in your case would be to connect the BL8000 to the BLC (NL/ML converter). Set the BLC as VMaster (do not connect speakers to the BS9000).
    To use a remote and simple start the BLC you could add a BLC IR-eye to the mix.
