Home Forums General Discussion & Questions BeoWorld Feature / Problem Search issue in forum 2012-2022
Viewing 7 posts - 1 through 7 (of 7 total)
  • #68114
    Pindsen
    If I try to search for a topic, could be “Beogram CD 50” in the older forum 2012-2022 I get nothing. I tells me this “Sorry, we were unable to find any results using your search terms. Please change your search terms and try again.”
    Everything I try with gives the same message.
    Are there are problem with the forum?
    /Pindsen
    #68121
    Guy
    Not sure.  But as a temporary workaround, try using google and after the search term enter “site:https://archivedforum2.beoworld.org/forums/”  without the quotation marks.
    eg: beogram 6000 site:https://archivedforum2.beoworld.org/forums/
    • This reply was modified 4 weeks, 1 day ago by Guy.
    My B&O Icons: No description available No description available No description availableNo description availableNo description availableNo description available No description available No description availableNo description availableNo description availableNo description availableNo description availableNo description availableNo description available
    #68368
    Pindsen
    Okay, the Google string works, it provides the search results in separate links – but it’s useable.
    I just tried if the search function works Today, but still get the same message:
    /Pindsen
    • This reply was modified 3 weeks, 4 days ago by Pindsen.
    #68857
    MJBeo
    GOLD Member
    Hi, I also get no response from any https://archivedforum2.beoworld.org/
    Also if I see a link in the google search with archivedforum2 it does not open (I often search [my question] site:beoworld.org).
    Would be great if that could be fixed somehow, since I have ML and MCL and rely on the older forums quite a bit.
    Cheers
    #68860
    Guy
    Thanks for highlighting.  I have just reported the problem to Multicare.
    #68887
    Guy
    @MJBeo – ArchivedForum2 should now be working, but its ‘search’ function is still work in progress.  The google search (using site: etc) should be a useable workaround in the meantime.
    #68897
    MJBeo
    GOLD Member
    Great, thanks!
