Home › Forums › General Discussion & Questions › BeoWorld Feature / Problem › Search issue in forum 2012-2022
- This topic has 6 replies, 3 voices, and was last updated 7 months, 3 weeks ago by
MJBeo.
1 August 2025 at 15:57 #68114
Pindsen
BRONZE MemberHi,
If I try to search for a topic, could be “Beogram CD 50” in the older forum 2012-2022 I get nothing. I tells me this “Sorry, we were unable to find any results using your search terms. Please change your search terms and try again.”
Everything I try with gives the same message.Are there are problem with the forum?
/Pindsen
1 August 2025 at 17:28 #68121 GuyModeratorAre there are problem with the forum?
Not sure. But as a temporary workaround, try using google and after the search term enter “site:https://archivedforum2.beoworld.org/forums/” without the quotation marks.
eg: beogram 6000 site:https://archivedforum2.beoworld.org/forums/
5 August 2025 at 19:43 #68368Pindsen
BRONZE MemberOkay, the Google string works, it provides the search results in separate links – but it’s useable.
I just tried if the search function works Today, but still get the same message:
Sorry, we were unable to find any results using your search terms. Please change your search terms and try again./Pindsen
18 August 2025 at 10:06 #68857 MJBeoGOLD MemberHi, I also get no response from any https://archivedforum2.beoworld.org/
Also if I see a link in the google search with archivedforum2 it does not open (I often search [my question] site:beoworld.org).
Would be great if that could be fixed somehow, since I have ML and MCL and rely on the older forums quite a bit.
Cheers
Favourite Product: Master Control Panel
18 August 2025 at 11:09 #68860 GuyModeratorThanks for highlighting. I have just reported the problem to Multicare.
19 August 2025 at 09:02 #68887 GuyModerator@MJBeo – ArchivedForum2 should now be working, but its ‘search’ function is still work in progress. The google search (using site: etc) should be a useable workaround in the meantime.
19 August 2025 at 11:38 #68897 MJBeoGOLD MemberGreat, thanks!
