Home Forums Product Discussion & Questions BeoVox RL 60 ABR replacement
Viewing 14 posts - 1 through 14 (of 14 total)
  • #47847
    graydonslc
    Member
    I’ve got a pair of RL 60’s that I bought with no ABR. I’ve looked up some posts that have a plate that can be 3d printed. Can anyone guide me in the right direction, as to be sure I repair the speakers properly. The printed parts I found on line ( Files ) are out there, but has anyone tried them ? The files I found are on yeggi.com under Bang & Olufsen RL 60 . If there are others I should explore can you please let me know.
    Thanks guys
    Stephen ( Graydon )
    Favourite Product: Beomaster 4000
    #47848
    premiumverum
    Hi Stephen,
    Looks pretty nice, I think it will be hard to find a better replacement anywhere.Worth a try!
    I saved a picture of an official ABR replacement once, I’ll add it to this post. Looks very similar.rl60-baspoort
    #47849
    Evan
    GOLD Member
    Happy to help print the parts if you decide to do so, just PM me. Although I can’t verify the fitment as I don’t have a pair of those speakers on hand.
    #47850
    graydonslc
    Member
    Hi Evan
    Thanks for the offer to print the parts. I went to the SLC Library today and they are going to try and print one out for me. Not sure if it will fit their machine. They said they would try but it will print on an angle with supports. You probably know more about that than me. If it fails they wont charge me, and I’ll be sending you a note. Either way I’ll let you know what the outcome is. I really appreciate the offer of help. I also found a file for the tube that attaches instead of PVC pipe. It will look just like the B & O replacement part. We will see …..Again Thank You
    #47851
    Evan
    GOLD Member
    Either way – let us know how it turns out! For future use it would be good to attach copies of the exact files used. All I could find was the plate with a hole in it.
    #47852
    graydonslc
    Member
    Hi Evan
    Here are the files for the parts I had printed. Over all the parts came out NICE. A little touch-up with a dremel tool and they fit perfect and tight. I’ll be putting them together tonight with silicone glue and test run will follow in the morning.   IMG_20230810_150152385IMG_20230810_150208398IMG_20230812_154203469
    #47853
    graydonslc
    Member
    The system won’t let me post STL files. Here is the site for the plate  https://www.thingiverse.com
    Search Bang & Olufsen Redline 60 repair plate. For the port I went to https://grabcad.com/library/beovox-redline-60-port-1#! On that web site I did have to make an account to down load.
    Both Sites list STL files for 3D printing of the parts. I put them on a thumb drive and my local library printed them for the cost of the plastic.
    (Just a note …the 2 holes in the center of the plate need to filled with silicone. They are guide holes if you want to print a filler plate. I felt no need to do this. We will see ..right ? )
    Thanks Stephen
    #47854
    Evan
    GOLD Member
    Hey Stephen – looks really good! Only thing I would add is some dynamat or similar material to dampen that plate a bit.
    Congrats!
    #47855
    premiumverum
    Very nice!
    Do seal the holes. They may cause whistling noises. I agree with evan on the damping material, the seal between the plate and the rest of the housing should be airtight and not rattle to prevent noises.
    #47856
    graydonslc
    Member
    Hi again
    Well I took Evans advice and added some damping to the plate.( Dynamat ) The plates were sealed with silicone and air tight for sure. They are now assembled and sound fantastic. They sounded like rubbish before the upgrade and now sound nearly as good as my RL60-2. I think the difference is the woofers. I understand they made a change on the RL60-2 woofers. ( Correct me if I’m wrong. ) But none the less they sound very good AGAIN. Thanks for your replies and advice on the repairs. Went far better, and easier than I anticipated. Another pair of B & O speakers saved.
    If anyone has any questions about the repair, please feel free to e-mail me or post it.
    My best to all
    #47857
    premiumverum
    Thanks for the update and thanks for sharing the process! Great find and great project!
    RL60 are a very nice loudspeaker. I read on beoworld that the original ABR’s were a tad better in the bass deparment then RL60.2 with its bass port, but at the cost of fragility with the foam.
    Finally a solution to save these nice speakers.
    #47858
    Evan
    GOLD Member
    Glad to read the follow up and happy the speakers are performing the way they should!
    #123772
    Zebedee
    Hi Stephen,
    I’m new to this forum so the timing of this post is possibly too late for you however I have today just finished rebuilding the ABR panel and panel surround.
    The metal skeleton surround frames I already had but one of the ABR metal panels was missing. I had a local metal shop cut out a rectangle from 1.2mm thick steel plate and I went home and ground a radius on the four corners to match my pattern part. Then came the fun part…
    I used a piece of 1mm thick neoprene (from an ebay supplier for £5.00) and placed it onto a flat board. I used masking tape to stretch and tension the neoprene evenly around all of its sides. I then placed the skeleton frame onto this neoprene sheet and used superglue to stick it down. Once that was dry, (about 30 minutes) the solid metal panel can be cleaned and glued down to the neoprene sheet  – inside the skeleton frame To get this accurately positioned, I placed it in the desired position and used three pieces of making tape – about 6″ long to act as hinges and used these to stick across the panel and one side of the skeleton frame. I made a tab to aid lifting the panel from another piece of masking tape and then hinged the panel in to an ‘open’ position to apply superglue and then hinged it back down to glue it together – see photos.
    If you need to ask me any questions please feel free.
    Favourite Product: 5000 system
    premiumverum
    Hello everyone.
    I spotted this online and could not resist buying it: an original ABR replacement set part nr 8480180. It suits the redline 45 as well as redline 60. Here are some pictures with measurements for future reference.
