Home › Forums › Product Discussion & Questions › BeoMaster › Replacing lamps on Beomaster 1001
- This topic has 4 replies, 2 voices, and was last updated 1 year, 11 months ago by
Knutte.
27 February 2024 at 01:34 #53072
Knutte
BRONZE MemberHas anyone performed a lamp replacement on a Beomaster 1001 or similar and have any hints to offer. I have understood that unit is opened with the backside facing upwards and that it has got hinges which make it possible to open the unit “as a book”. From what I’ve seen in images, it looks like two of the lamps are easy accessable but I’m worried about the other two. Any hints are highly appreciated.
27 February 2024 at 13:51 #53073Dillen
ModeratorThe large dial plate will have to be losened.
That’s four screws from below.Open the Beomaster and swing the bottom section away from the top section.
Push the dial pointer to a place where you can access its fastening to the string.
Mark up on the string where it is fitted to the pointer so you can fit it back in the
same place, remove one of the two small screws and losen the other so you can
swing the small clear plastic string holder away from the string which zigzags under it and between the screws.
Then take out the four screws holding the dial plate.
When done, make sure to align the dial plate correctly, so that both the dial
pointer and the sliding knobs are free to travel.(Same procedure for Beomaster 1200).
27 February 2024 at 14:57 #53074Knutte
BRONZE MemberThanks Martin. Just to make sure I understand correctly, is it the board in the read figure below that needs to be loosened before I can access the lamps?
Cheers!
27 February 2024 at 18:07 #53075Dillen
ModeratorNo! Not the circuit board (that’s not an easy task).
The large dial panel = the large black metal facia with the white lettering/frequencies
and channels, that the sliding dial pointer travels on, – that also holds the lamps.
One screw each corner of the panel (= two screws each end of the Beomaster).Martin
3 April 2024 at 21:36 #53076Knutte
BRONZE MemberNow I’ve finally opened up my Beomaster and understands what @Dillen wrote about dial pointer and dial plate. 🙂
When it’s time to reassemble the dial pointer ((3190047) ) I will try to replace the window and the two plastic guide plates (3015015). Anyone have any hints to offer for this? The window is glued to the plastic ends of the dial pointer right?
[Edit]
Added this question to a new topic below instead:
https://forum.beoworld.org/forums/topic/rebuilding-the-dial-pointer-on-beomaster-1001/ -
