Home › Forums › General Discussion & Questions › General Discussion & Questions › Removing a Beovision V1 from a swing opening wall bracket
- This topic has 2 replies, 2 voices, and was last updated 2 weeks, 6 days ago by
Simon Ellis.
15 November 2025 at 18:12 #71192
Simon Ellis
BRONZE MemberCan any advise me on how to remove a Beovision v1 from its custom wall bracket which swings out from the wall.
You must be logged in to view attached files.16 November 2025 at 11:16 #71206 GuyModeratorI’ll try to attach the instructions as I am not sure if they are on the site elsewhere.
As you can (hopefully) see the metals rods slide into the casing of the TV, and are release with little hidden catches top and bottom (diagram 10 on the pdf). The TV then needs separate rod assemblies to replace the bracket parts, if that makes sense!
It may be best to unscrew the whole assembly from the wall and then remove the bracket part.
EDIT: The manual is also still listed on B&O’s support page: https://bangolufsenassistentgohe.blob.core.windows.net/manuals/TELEVISIONS/BEOPLAY%20V1/Wall_Bracket_BeoPlay_V1.pdf
This reply was modified 3 weeks ago by
Guy.
You must be logged in to view attached files.Location: Warwickshire, UK
17 November 2025 at 11:44 #71325Simon Ellis
BRONZE MemberThank you Guy,
This is really helpful as I had already removed the whole thing from the wall (bracket and TV) and was now considering how to take the next step. What a great support community!
