Home › Forums › Product Discussion & Questions › BeoSound › Region Code for integrated DVD in Beovision7-40.
- This topic has 5 replies, 2 voices, and was last updated 2 years ago by
loureed5.
4 April 2024 at 04:27 #54078
loureed5
BRONZE MemberHow can I make the inbuilt DVD in the Beovision 7-40 region free.?
Step 10 in the Keith Saunders instructions requires LIST on the Beo4 until “Shift”
I have 3 different Beo4 remotes , and can’t find the “Shift” command on any of them
Help needed please
Noel.
4 April 2024 at 20:06 #54079 GuyModeratorTo add SHIFT to the Beo4:
– Press Power (Red Button) and LIST together, the display should read ADD?
– Press GO.
– Press LIST until the display shows SHIFT then GO.
– SHIFT should then be listed under LIST
5 April 2024 at 05:04 #54080loureed5
BRONZE MemberHi Guy,
Thanks heaps for your reply- I now have SHIFT on the Beo4 !
I followed Keith’s instructions , but still not region free.
It does say it’s important to disconnect the DVB-T module before making the DVD
Region Free.
Where will I find the DVB – T ?
regards
Noel.
5 April 2024 at 08:44 #54081 GuyModeratorI assume from the earlier thread that you have access to the ‘special’ Beo4 remote hence are able to get the REG2 command to show.
I too am not sure what is meant by ‘disconnect the DVB-T module’, but if you look at this FAQ it describes the DVB-T in some detail which may enable you to work out how to disconnect.
https://beoworld.org/faq_view.asp?id=93
5 April 2024 at 11:14 #54082loureed5
BRONZE MemberHello again Guy,
You’re right – thanks to Mr 10% I now have the special remote that
shows the REG 2 command. And thanks to your advice , I have now got SHIFT as a
command on the Beo4.
After all that I still can’t make the DVD region free,
Regards
Noel.
5 April 2024 at 13:30 #54083loureed5
BRONZE MemberKeith advised me that I need the special remote that has “Special Command 2”
on it,
Regards
Noel. -
