Home › Forums › Product Discussion & Questions › BeoVision › Region Code for integrated DVD in Beovision7-40.
- This topic has 6 replies, 3 voices, and was last updated 2 years, 12 months ago by
loureed5.
2 April 2023 at 05:38 #45347
loureed5
BRONZE MemberHoping someone can help set me straight on the in-built DVD in the Beovision7- 40.
The unit has defaulted somehow to play only Region 2 discs, not Region 4 which is Australia’s
region code.
Is there anything I can do to change it back to Region 4, or multi-zone it, or will it have to go to a service centre ?
regards
Noel
2 April 2023 at 06:08 #45348 GuyModeratorHi Noel,
I had a quick look at the service manuals (available here) and they state that the ‘Service Tool’ is required to change the region code, so unfortunately you will need to contact a service centre – perhaps ask them to visit you if they have the tool which could be easier than moving the TV.
It is strange that the code has changed, but I think I have read about this problem before on one of the archived forums. The service manuals do also explain how to check (but not change) the current codes.
EDIT: See also this thread about a special remote: https://archivedforum2.beoworld.org/forums/p/38034/289325.aspx#289325
2 April 2023 at 19:44 #45349 Keith SaundersBRONZE MemberWhilst the region setting can be change with the service tool, its not a requirement.
Eleven years ago I wrote the attached document and made an XML file for the Beo5/6.
Attached is the Procedure for setting a Beovision 7 & AVANT DVD to Region Free
3 April 2023 at 11:35 #45350loureed5
BRONZE MemberThanks for all the help guys.
Thanks Keith for the procedure sheet- but how do I disconnect the
DVB-T module ?
regards
Noel.
3 April 2023 at 11:51 #45351loureed5
BRONZE MemberAnd the sheet refers to a “special” Beo4 Remote ?
3 April 2023 at 13:19 #45352 Keith SaundersBRONZE MemberAnd the sheet refers to a “special” Beo4 Remote ?
You only have the two options and the procedure provides the instructions for both.
- Get hold of the “Special Command 2” Beo4
- If you have a Beo5/6 and you load the XML file which I built 11 years ago and I can supply.
If you do not have one of above, then you will not be able to make it region free.
3 April 2023 at 14:10 #45353loureed5
BRONZE MemberHi Keith,
Many thanks for your reply, and supplying the procedure sheet.
I will have to try and get access to the special remote.
regards
Noel.
