Home › Forums › Product Discussion & Questions › BeoSystem › Program beo1000 remote for aux
- This topic has 6 replies, 3 voices, and was last updated 1 year, 7 months ago by
Guy.
29 August 2024 at 04:27 #58672
Mike Scott
BRONZE MemberWe inherited an old beosystem2500 from a family member, and a beo 1000 remote. We are using the aux port to stream music to it, and I cannot find where/how to program a button to select AUX as a source. No info is in the manual so I figured I’d post and ask.
thank you in advance!
29 August 2024 at 05:11 #58673Madskp
GOLD MemberThe PHONO button on the Beolink 1000 should activate the AUX source
29 August 2024 at 09:31 #58676 GuyModeratorOr press SHIFT then RADIO
(but I agree that PHONO should work too 😀)
30 August 2024 at 03:38 #58696Mike Scott
BRONZE MemberPhono button activates the phono input. It is shift and then radio, not shift and radio at the same time.
30 August 2024 at 03:39 #58697Mike Scott
BRONZE MemberThis was it. In succession not at the same time.
any way to turn off the lights in the back while it’s on?
also – any idea if the unit has a sleep timer?
thank you again for the help
30 August 2024 at 06:02 #58698Madskp
GOLD MemberPhono button activates the phono input. It is shift and then radio, not shift and radio at the same time.
While it says phono in the display it is the AUX connection it is activating. So this is by far the easiest way
You can also press shift and the A.Tape. The it will show Tape2.Location: Denmark
30 August 2024 at 08:06 #58703 GuyModeratorIt is shift and then radio, not shift and radio at the same time.
Yes, that’s what I said! 😀 (but as madskp says, PHONO is just one button press hence easier if you are happy for PHONO to show in the display)
No
Yes but only whilst playing RADIO. Press STOP until the required number of minutes shows in the display.
