Home › Forums › General Discussion & Questions › General Discussion & Questions › problème son
- This topic has 3 replies, 2 voices, and was last updated 3 years, 2 months ago by
@Lex.
23 January 2023 at 09:13 #43253
@Lex
BRONZE MemberBien le bonsoir,
J’ai fourni d’un Beogram 3300 avec ses deux Beovow LR45. Les fils des haut-parleurs avaient été coupés. J’ai donc acheté des nouveaux câbles 2Pin DIN male 5ft.
Maintenant qu’ils sont connectés, un bruit fort sort des enceintes avant meme que j’allume la radio ou la platine vinyle. Je ne suis pas calée en Hi-fi rétro mais j’adore cette platine et ma collection de vinyle attend vos précieux conseils.
Merci d’avance
Good evening,
I inherited a beogram 3300 with its two Beovow LR45s. The speaker wires had been cut. So I bought new 2Pin DIN male 5ft cables.
Now that they are connected, a loud noise comes out of the speakers before I even turn on the radio or the turntable. I’m not savvy in retro Hi-fi but I love this turntable and my vinyl collection await your valuable advice.
Thanks in advance
24 January 2023 at 03:41 #43254 Mark-sfBRONZE MemberWelcome! Your problem is likely the amp and not the turnable. Which amp do you have the speakers plugged into? Can you describe the nature of the noise (hum, hiss, thumps, etc)? Does it have a headphone jack you can try? If so do you hear the same noise?
24 January 2023 at 19:50 #43255@Lex
BRONZE MemberBonsoir et merci Mark-sf pour la réponse.
Ce sont deux beovox sur un beomaster 3300 avec platine vinyle beogram 3300 et beocord 3300. Et le bruit c’est un bourdonnement.
27 January 2023 at 09:58 #43256@Lex
BRONZE MemberGood evening and thank you Mark-sf for the answer.
They are two beovox on a beomaster 3300 with beogram 3300 turntable and beocord 3300. And the noise is a hum.
it’s not recurrent, it’s a dull buzzing that comes and goes.
