Home › Forums › Product Discussion & Questions › BeoSound › Problem with Beosound Core and local sources
- This topic has 9 replies, 5 voices, and was last updated 2 years, 7 months ago by
SaltineSurfer.
12 August 2023 at 04:05 #48192
patcherley
GOLD MemberFirstly, I would like to echo what YannChris said about the lack of user manuals, I have spent ages going through every screen I could find to try and set up the Core. I have only just found the screen to tell the Core what type of speaker it is attached to!
I have a Beovision Eclipse, Beomaster7000 (with CD, Cassette tape, Beogram and a OneRemote), and a NL/ML converter.
On the setting up local sources screen, I can see all my Eclipse and Masterlink sources and have selected the ones I want. But on the screen to select the source to play I can only see one Eclipse source and one Masterlink source and I think these were there before I selected any local sources.
Any ideas on what I can do?
Also, I thought I would have B&O Radio on the Core but have Tunein.
Regards Paul
Favourite Product: Beolink 7000
12 August 2023 at 18:38 #48193Stan
BRONZE MemberI don’t have a Core, but on my Essence, when I check the local sources, they immediately show up in my sources pick list
The fact that you’re not seeing B&O Radio, maybe you need to upgrade your app? Also, go into the TuneIn/B&O Radio tab on the app (the little transmit icon in the lower right corner of the app), and click on the B&O Radio tab, this might prompt for a TuneIn -> B&O Radio upgrade.
12 August 2023 at 19:31 #48194patcherley
GOLD MemberThe app shows B&O radio but it also says the Core does not support it. Will carry on investigating. Paul
12 August 2023 at 21:23 #48195 BeoToolBRONZE MemberLook for an upgrade to the Core software. The latest should give you B&O Radio.
13 August 2023 at 12:33 #48196patcherley
GOLD MemberAn update. I did a factory reset and this time I made the BLC the primary Beolink product and the Eclipse the secondary Beolink product and I can both select the Masterlink sources in the local sources screen and then choose them in the app and on the remote. I can select the Eclipse sources in the local sources but they do not show in the app or the remote. I can join a playing Eclipse source.
Still no B&O Radio and I appear to be at the last version of the software, 2.1.50871.22855122.
Paul
13 August 2023 at 22:29 #48197 BeoToolBRONZE MemberI have 2.1.51942 for my Core/Shape. To be fair, I was a member of the beta test team for a time; nevertheless, I believe this is the current release version.
14 August 2023 at 06:21 #48198 carolpaBRONZE MemberAn update. I did a factory reset and this time I made the BLC the primary Beolink product and the Eclipse the secondary Beolink product and I can both select the Masterlink sources in the local sources screen and then choose them in the app and on the remote. I can select the Eclipse sources in the local sources but they do not show in the app or the remote. I can join a playing Eclipse source. Still no B&O Radio and I appear to be at the last version of the software, 2.1.50871.22855122. Paul
Did you set the Radio preference for your system/Core to TuneIn or B&o Radio?
To do so:
select Radio on the app
select “settings”
select “Radio services”
select “Bang & Olufsen Radio”Note: only sources of primarily set Beolink Products are visible (a change after one of the sw updates)
14 August 2023 at 12:58 #48199patcherley
GOLD MemberCarola, thanks for that about the primary, I thought I had seen something like that but couldn’t find it.
I have spoken to my local dealer who sold me the core and they said the same about the preference but I already had it set. They have raised a call with B&O about B&O Radio. Will report back on response.
14 August 2023 at 16:17 #48200patcherley
GOLD MemberJust had a response from B&O support. It is a known issue which they are working to fix. There is a temporary solution to switch the radio back to Tunein and then back to B&O Radio, this works for me.
It might be that I migrated to B&O Radio before adding the Core.
15 August 2023 at 14:45 #48201SaltineSurfer
BRONZE MemberI’m also waiting patiently for this issue of the secondary linked products not being accessible in the local list menu to be fixed. It affects all of my ASE products on the new firmware with b&o Radio.
