Home › Forums › General Discussion & Questions › General Discussion & Questions › PowerLink wiring advice BeoSound 9000, BeoLab 8000 and BeoLab 2 – 5 or 8 pin?
- This topic has 2 replies, 3 voices, and was last updated 1 year, 2 months ago by
Guy.
1 February 2025 at 14:39 #63292
Eric
BRONZE MemberHi,
I need some advice regarding PowerLink wiring. Is a PowerLink cable necessary to fully utilize a BeoSound 9000 (MK3), BeoLab 8000 (MK1), and BeoLab 2? Or is a 5 pin cable sufficient?
Thanks!
2 February 2025 at 09:21 #63305 TignumGOLD MemberHi Eric, Mk3 will do. Check Steve’s site: https://soundsheavenly.com/powerlink-8-pin-din-connection/20-272-powerlink-mk-3-compatible-8-pin-din-cable-with-4-cores-wired-low-profile-cable.html#/9-length-18m
“This cable is perfect for use with all Beolab speakers that do not have displays (although not suitable for Beolab 5 – this needs mk 2).”
Here there is some more insight: http://www.soundsheavenly.com/faq/guide-various-types-powerlink-cable-bang-olufsen-use/
Regards, Johan
2 February 2025 at 13:16 #63309 GuyModeratorGood advice above – I would go for PL Mk3 cables from Steve.
However, you also asked about the 5-pin DIN cable in your post. Checking the service manual of BL8000, the input makes no use of PL pins 6, 7 or 8. This would suggest that a 5-pin DIN cables would indeed ‘work’, but there is no guarantee that L&R signal connections (pins 3&5) are correctly shielded, hence best to stick with the correct cable. I can’t find the circuit diagram for Beolab 2, but this may be the same.
