Home › Forums › General Discussion & Questions › General Discussion & Questions › Powerlink Speaker Sense plug wiring?
- This topic has 8 replies, 5 voices, and was last updated 2 years, 2 months ago by
Djmp.
8 January 2024 at 11:29 #52028
Djmp
BRONZE MemberHi,
I would like to make a Powerlink Speaker Sense plug (also called an Option 1 plug) to enable the remote control on a Beosound 9000 being used for line out audio. Does anyone have a wiring diagram for it?
Thanks!
9 January 2024 at 01:17 #52029NQVHNWI
BRONZE MemberHave a look on Sounds Heavenly. They have a trigger product (BL7.1-7.4) IIRC which may be of use?
9 January 2024 at 05:32 #52030Djmp
BRONZE MemberThanks. I want to make my own. I’m guessing it’s something simple like a resistor on the enable pin.
9 January 2024 at 08:45 #52031B3OHACK3R
BRONZE MemberHi,
there aren’t many possibilities for the music system to find out if speakers are plugged in out not. I haven’t tested it but your guess doesn’t sound wrong. Put a tiny load on the ON/OFF signal pin and it will probably work. Something like 100k to ground might be worth a try.
9 January 2024 at 11:24 #52032 GuyModeratorHave a look here: https://archivedforum.beoworld.org/forums/p/42495/352266.aspx#352266
9 January 2024 at 12:12 #52033 RavstedBRONZE MemberI once wanted to connect a non-B&O subwoofer to Beovision 5. If I remember correctly I also soldered PIN 2 to PIN 4 … And obviously soldered the proper PINs to the RCA cable going to the SUB.
For the BeoSound 9000 the trick with the headphone jack seems even better….
9 January 2024 at 16:13 #52034 RavstedBRONZE MemberAccording to the legend Peter Pan a 68k ohm resistor is needed between pin 2 and 4
https://hifi4all.dk/forum/forum_posts.asp?TID=23818&PN=0&TPN=68
9 January 2024 at 16:20 #52035 RavstedBRONZE Member9 January 2024 at 21:57 #52036Djmp
BRONZE MemberPerfect!
