Home › Forums › General Discussion & Questions › General Discussion & Questions › PowerLink – Pin out for 5V trigger
- This topic has 4 replies, 2 voices, and was last updated 4 years ago by
ajames.
24 March 2022 at 11:31 #33522
ajames
SILVER MemberI have a playmaker and I’ve got the cat to powerlink female adaptor cable, which I use to connect to a Quad Power Amp – what I want to do is use the 5V trigger on the powerlink cable to trigger a relay to power up the Quad Amp rather than having to manually switch it on and off – does anyone know which pins provide that – I’m having trouble to find it on any technical details.
Favourite Product: Beocentre 9300
24 March 2022 at 11:31 #33523ajames
SILVER MemberI mean the pins on the Powerlink Din cable
24 March 2022 at 12:34 #33524 GuyModeratorPowerlink Pin 4.
I am posting for the second time because the first disappeared, possibly because I inserted a link.
24 March 2022 at 12:59 #33525 GuyModeratorPowerlink pin 4 is the one you need.
I often refer to PeterPan’s diagrams to check – scroll through the thread until you find what you need: https://www.hifi4all.dk/forum/forum_posts.asp?TID=32157&PN=1
24 March 2022 at 13:17 #33526ajames
SILVER MemberGreat, thanks Guy – got what I needed – I’ve bookmarked it – it’s excellent – thanks again
