Home › Forums › Product Discussion & Questions › BeoLink › Powerlink Comptability
- This topic has 40 replies, 5 voices, and was last updated 11 months, 3 weeks ago by
CharlieWednesday.
3 January 2025 at 18:37 #62226
Madskp
GOLD MemberInspired by different threads I want to explore the subject of Powerlink compatibility for certain situations where in all cases a fully wired Powerlink MK2 cable is needed:
1) Functionality to turn on the passive speaker amplifiers like MCL2P and Beolink Passive
2) Functionality to drive a MCL network of the Powerlink connection via a Beolink Passive
3) Display the source and volume in the speaker displays (Beolab 3000/4500/5000/Penta)
The info provided in this post is to start with is from my own testing and input from other threads which I have tried to link to. Any input from other users are very welcome and I will try to update this first post accordingly.
Powerlink MK2 VS MK3
First I just want to point of the differences of Powerlink MK2 and MK3 cables that has influence on this subject.
Powerlink MK2 cables are fully wired, meaning that all 8 pins in the DIN connector is in use:
Pin 1 Power up
Pin 2 Ground
Pin 3 Left channel
Pin 4 Speaker on/off (I have also seen this referred to as mute)
Pin 5 Right Channel
Pin 6 Data
Pin 7 Data ground
Pin 8 Power Failure/Overlad
Powerlink MK3 cables are not fully wired, but only have the following pins connected:
Pin 2 Signal ground
Pin 3 Left channel
Pin 5 Right channel
Pin 6 Data (not present in the ø2.5mm Powerlink cables)
Pin 7 Data ground
Note that all pin numbers refer to DIN connectors. For RJ45 Powerlink connectors the pin numbering is different than for the DIN connectors.
As the MK3 Powerlink cables do not have Pin 1 they can not be used for activating the passive speaker amplifiers mentioned in this thread
1 Powerlink activated amplifiers
The Powerlink connected amplifiers referred to in this thread are:
– MCL 2P type 1741- 1745
– Beolink Passive type 1655-1658
– ML/MCL Converter type 1650-1653 (the unit is the same as the Beolink passive just with an other product name and type numbers)
All these amplifiers can only be activated by pin 1 in the Powerlink connection as pin 4 is not connected internally in them.
herefore it is crucial to use a fully wired Powerlink MK2 cable to activate these amplifiers. However the source also has to supply the activation voltage on pin 1 in it’s Powerlink connection for this to work. This is the case for a lot of B&O products with Powerlink. However there are a few outliers that does not supply the voltage on pin 1, and therefore pin 1 and 4 in the Powerlink cable has to be switched in one end for it to work.
2 MCL via Powerlink
In some B&O system the datalink86 connection in the AUX connection is connected internally to the speaker 2 connectors data connection for use with a MCL system, and to the data connection in the Powerlink connectors. In these cases the datalink signals are transmitted to all these connections, and MCL products like the Beolab 3500 MK1 can with the correct wirering be connected directly to a Powerlink connection on a compatible audio system like explained in this post https://forum.beoworld.org/forums/topic/bl3500-and-the-mcl-pl-connector/page/4/#post-44614
On the Beocenter 2300/2500 that came without a built in power amplifier the Powerlink ports could be connected to a Beolink Passive to amplify the sound to MCL speaker levels. The data signals are just passed through from the Powerlink input to the MCL data connection on the Beolink Passive.
This was probably a transitional feature to support existing MCL link room system until built in Masterlink became a thing on B&O audio systems.
However on some other systems the same conversion from Powerlink to MCL can be done. This is as far as I know not documented, but this thread should help to give an overview of what is possible. Although it does not make much sense to have this feature in link room products like the Beolink Active, Beolink Wireless 1, MCL2AV etc. I have tried to test it just to be sure.
For speakers that has a built in display like Beolab 3000/4500/5000 and Beolab Penta a data signal is needed in order for the displays to work. Therefor Pin 6 has to be present in the Powerlink cable for these speakers. Therefore a Fully wired Powerlink MK2 cable is also necessary for this to work.
I do not have any of these speakers myself, and have therefore not been able to do any testing of this myself. I may look into other threads to find info, and other users are very welcome to share their experience with this.
Comptability overview
*1 When used as an amp for local passive speakers the amp will also be turned on if a link room is activated whereas local speakers will normally be muted. A work around is to make a special Powerlink cable where pin 1 and 4 is switched around)
*2 Based on: https://forum.beoworld.org/forums/topic/beolink-passive-ir-eye/page/3/#post-45824
*3 Based on: https://forum.beoworld.org/forums/topic/beolink-active-1636-pc-input/page/2/#post-43139
*4 At startup of the NL/ML converter the amp is powered on, and has a delay before going into standby. Both tested with the NL/ML converter setup as V.master and A.slave.
*5 Based on testing Beomaster 4500
*6 Pin 1 and 4 in the Powerlink connection have to be switched in one end https://forum.beoworld.org/forums/topic/beoplay-connection-hub-beolink-passive/#post-52181
*7 The amp is activated when the BM5 starts up, but will not start up again after standby in my test
*8 The display will show LOAD TAPE at startup and when switching source, and then show A.TAPE2 regardless of N.music or N.Radio playing
4 January 2025 at 10:25 #62246 GuyModeratorGreat information – many thanks for starting the thread and posting the data above!
My BC9500 works the same as BC2300 – turns Passive* on/off but no muting – see here . I haven’t driving MCL, nor have I tried the modified (pin 4 to 1) PL lead but will do so next time my BC9500 is set up.
My Essence Mk2 turns Passive on fine – fully wired RJ45 PL lead used. Hopefully @CharlieWednesday is testing MCL compatibility.
* EDIT: Was actually tested with MCL2P.
4 January 2025 at 10:43 #62248Madskp
GOLD MemberMy BC9500 works the same as BC2300 – turns Passive* on/off but no muting – see here . I haven’t driving MCL, nor have I tried the modified (pin 4 to 1) PL lead but will do so next time my BC9500 is set up.
Great info, thanks 🙂
It was actually that I had picked up from another thread, but I can see now that I have made the YES for the MK1. That will be corrected in the next version of the list
4 January 2025 at 13:00 #62255 carolpaBRONZE MemberMy BC9500 works the same as BC2300 – turns Passive* on/off but no muting – see here . I haven’t driving MCL, nor have I tried the modified (pin 4 to 1) PL lead but will do so next time my BC9500 is set up.
To my knowledge and experience all Beosounds / Beomasters will switch on the MC2P / Active / ML-MCL converter when connected with fully wired PL (even the BS Moment).
Note: never tested it on a BS5 or BS5e, but presumably it won’t work on a BS5 when “master” is set off.Also all MCL capable Beomasters will support MCL. That said: why use a seperate amp if the Beomaster is MCL ready (f.e. 4500, 6500, ….)?
4 January 2025 at 13:35 #62261Madskp
GOLD Membero my knowledge and experience all Beosounds / Beomasters will switch on the MC2P / Active / ML-MCL converter when connected with fully wired PL (even the BS Moment).
That would also be what I expect, but there could be outliers.
Actually on my BS5 it had some weird behaviour as described above. It could be something wrong with my unit.
Yes I know it is a little redundant, but my thought was to not only look at the outliers but get the full picture of Powerlink comptability in different products. Also could be workaround in case of a broken amp in the Beomaster/Beocenter
4 January 2025 at 15:05 #62267 CharlieWednesday
GOLD MemberMy RJ45-to-DIN fully wired powerlink cable arrived today from Sounds Heavenly (thanks Steve!), so I’ve started performing some tests.
To begin with, I went into the settings of my BS Essence and turned off the Integrated Setup option, then I connected that new PL cable to the PL1 socket.
Test 1 – BS Essence > BL Penta – Pass
This passed, with sound and display. The Penta’s came out of standby when I selected a source, and went back into standby when I put the Essence into standby. The displayed first showed LOAD TAPE when I powered it up, and also did that when I switched source between N.Radio and N.Music, but then after a few seconds displayed A.TAPE2, and the volume. It didn’t matter if I was listening to N.Radio or N.Music – both displayed as A.TAPE2 on the Pentas (Of course, I forgot to change the sound level settings in the Essence before I tested this, so now my entire village know the true power of the Penta!).
Test 2 – BS Essence > BL Passive > BV CX50 – Pass
Just a quick test to ensure that the new cable was able to power up the BL Passive, and drive the speakers. I connected a pair of CX50s. When I selected a source on the Essence, the BL Passive powered on and the source was heard.
Test 3 – BS Essence > BL Passive > MCL2AV > BL Penta – Partial Pass
When I selected a source on the Essence, the BL Passive powered on and the source was heard. No display on the Penta’s here, but I wouldn’t have expected that. I was not able to control anything via the IR Receiver (the old rectangular type) with my BEO4, but the Mute button on the IR Receiver did toggle the sound on and off, but you had to press it twice each time to toggle! The LEDs in the IR receiver worked, including the Timer LED, but I didn’t test if the timer was having any effect.
Test 4 – BS Essence > BL Passive > MLL2A > BV CX50 – Fail
In this test I got no response – the LEDs did not light up on the IR receiver and I got no sound. BUT: this is an MCL2A that I have only just got my hands on, and this is the first time I have tested it – it might be faulty, but I used this one as it is already fully wired up. When I have more time I will wire up another working MCL2A that I already had (but it is not currently wired up) and perform the same test again.
Test 5 – BL Essence > BL Passive > BL 3500 Mk1 – Unable to test
I have a BL 3500 Mk1 which has a DIN input for MCL, but I don’t have the right cable to test this and not enough patience or skill to create one myself, so this one will have to remain untested!
4 January 2025 at 15:20 #62270 CharlieWednesday
GOLD MemberOh I should add that while I did change the options in the BS Essence so it was no longer in ‘Integrated Setup’ mode, the remaining items in my ML/NL network remained connected (Beolink Converter NL/ML, Beosound 4, Beovision 7), and I noticed that my BS4 continued to display the selected source (either N.Radio or N.Music). I didn’t think to check if the display on the BV7 was also displaying the source.
5 January 2025 at 07:44 #62297Madskp
Thank you very much 🙂
Test 1 – BS Essence > BL Penta – Pass This passed, with sound and display. The Penta’s came out of standby when I selected a source, and went back into standby when I put the Essence into standby. The displayed first showed LOAD TAPE when I powered it up, and also did that when I switched source between N.Radio and N.Music, but then after a few seconds displayed A.TAPE2, and the volume. It didn’t matter if I was listening to N.Radio or N.Music – both displayed as A.TAPE2 on the Pentas (Of course, I forgot to change the sound level settings in the Essence before I tested this, so now my entire village know the true power of the Penta!).
Interesting result with great information of what to expect from this combination.
Test 2 – BS Essence > BL Passive > BV CX50 – Pass Just a quick test to ensure that the new cable was able to power up the BL Passive, and drive the speakers. I connected a pair of CX50s. When I selected a source on the Essence, the BL Passive powered on and the source was heard.
Great that this works as expected.
Test 3 – BS Essence > BL Passive > MCL2AV > BL Penta – Partial Pass When I selected a source on the Essence, the BL Passive powered on and the source was heard. No display on the Penta’s here, but I wouldn’t have expected that. I was not able to control anything via the IR Receiver (the old rectangular type) with my BEO4, but the Mute button on the IR Receiver did toggle the sound on and off, but you had to press it twice each time to toggle! The LEDs in the IR receiver worked, including the Timer LED, but I didn’t test if the timer was having any effect.
From my other testing I would expect a result like this. Becasuse the MCL2AV can operate stand alone it is able to open up the sound path from the MCL cable, but the data is not going through to the Passive/Essence. Also I belive the thing you experience with the LED’s is normal behaviour for the MCL2AV even in stand alone mode.
When you say that you were not able to control anything how did you activate the Essence in this case, via app?
I would think that the Penta’s would display something, but i might not be the case with the MCL2AV in stand alone mode, but only work if the MCL2AV is connected to a Beomaster/Beocenter.
Test 4 – BS Essence > BL Passive > MLL2A > BV CX50 – Fail In this test I got no response – the LEDs did not light up on the IR receiver and I got no sound. BUT: this is an MCL2A that I have only just got my hands on, and this is the first time I have tested it – it might be faulty, but I used this one as it is already fully wired up. When I have more time I will wire up another working MCL2A that I already had (but it is not currently wired up) and perform the same test again.
Also I would expect this as the MCL2AV can not operate stand alone like the MCL2AV
Test 5 – BL Essence > BL Passive > BL 3500 Mk1 – Unable to test I have a BL 3500 Mk1 which has a DIN input for MCL, but I don’t have the right cable to test this and not enough patience or skill to create one myself, so this one will have to remain untested!
Quite ok. I think test 3 does suffice.
5 January 2025 at 08:50 #62300 CharlieWednesday
GOLD MemberWhen you say that you were not able to control anything how did you activate the Essence in this case, via app?
I don’t remember for certain, but pretty sure I activated it with the app.
I didn’t think the Penta displays would ever work through an MCL2AV. We’re having work done in the house so my Beocenter 8500 is in storage, but when I get it back, I’ll have to test that!
5 January 2025 at 12:52 #62303Madskp
Thanks for the update. I will update the first post accordingly
25 February 2025 at 18:49 #64050Madskp
GOLD MemberReading this post https://forum.beoworld.org/forums/topic/low-budget-multiroom-setup-for-ceiling-speakers/#post-64021 by Steve from SoundsHeavenly I am wondering if there is something we have overlooked regarding the Esssence ability to active a Beolink Passsive /MCL2P.
@CharlieWednesday you dit mention that you only tested it briefly, but @Guy have you used the MCL2P with the Essence over a longer period of time?Location: Denmark
25 February 2025 at 19:52 #64064 GuyModerator@Guy have you used the MCL2P with the Essence over a longer period of time?
Not really for a longer sustained period (like Steve suggests), but I have often used my Essence to power a Passive with a fully wired PL to RJ45, and never experienced problems turning on or off.
In support of that other thread, I did some quick comparisons today between the Pin 1 and 4 PL outputs on BeoCenter 2300, Essence Mk 2 and NL/ML Converter (obviously looking at RJ45 pins 5 and 4 respectively on the latter two). Let me just make up a table of the results and I will post back here. Might have to do a jpg as I can’t remember how to post a table!
25 February 2025 at 20:47 #64065 GuyModeratorHere we go – all pin voltages are approximate and were tested while Beolink Passive was connected:
The only real surprise* from my limited testing above is for the NL/ML Converter and the fact that the Passive does not switch off reliably with the fully wired RJ45 to PL cable, due to the voltage remaining at the Passive’s PL pin 1 for a period (a few seconds to a few minutes). I used my little adaptor to move RJ45 pin 4 to pin 5 and it switched off reliably straight away.
* EDIT: I shouldn’t really have been surprised because you noted this delay in Note 4 of your table at the first post!!! 😀
No such problems with the Essence but I haven’t conducted a long term test.
I suspect that the Core behaves like the NL/ML Converter hence the requirement for a modified cable.
Finally, I didn’t really explore ‘muting’ for the Essence or NL/ML Converter – I think these mute internally rather than switching the amp off but cannot be sure how it would behave if for example the Essence was supplying a source to a linked NL device in another room. To be honest there are so many settings in the NL devices (integrated versus linked, local sources, etc) that it becomes confusing and is difficult to be sure what you are testing!
25 February 2025 at 21:22 #64069 GuyModeratorSorry, one other observation: When the Essence Mk2 was connected to the Passive, if I then used my little adaptor to route the Essence RJ45 pin 4 to the Passive’s PL pin 1 then there was a distinct ‘pop’ from the speakers when the Passive was activated. The ‘pop’ didn’t occur when the straight-through, fully wired RJ45 to PL cable was used.
26 February 2025 at 15:43 #64098Madskp
GOLD MemberThanks for your observations.
For some reason I can not see the picture you have inserted. I know that there was an issue with inserting pictures yesterday that Mark fixed, so maybe you could try to insert it again?
26 February 2025 at 17:30 #64103 GuyModeratorso maybe you could try to insert it again?
Done 😀
26 February 2025 at 18:49 #64104Madskp
GOLD Memberhmm weird I can still not see it I only get this both on my phone and computer:
26 February 2025 at 21:11 #64118 GuyModeratorStrange – I have tried inserting it again, but if that doesn’t work, here it is as an attachment:
You must be logged in to view attached files.Location: Warwickshire, UK
27 February 2025 at 08:18 #64138 peppsModeratorThat’s better with the attachment now @Guy 👍
Favourite Product: Beosystem 6500
27 February 2025 at 10:05 #64142 -
