Home › Forums › General Discussion & Questions › General Discussion & Questions › Powerlink Cable
- This topic has 10 replies, 6 voices, and was last updated 4 months, 4 weeks ago by
Ravsted.
10 January 2023 at 02:05 #42666
GuyModeratorSteve’s post here gives some advice about Cat 6 or 7: https://archivedforum2.beoworld.org/forums/p/26569/212622.aspx#212622
Here are the diagrams for RJ45 to RJ45 from the handbook:
And here’s some info about whether to use 2.5mm or 5 mm:
10 January 2023 at 12:51 #42663Frog
GOLD MemberHi,
I’m attempting to make my own powerlink cables which use RJ45 connectors- but am puzzled about the cable to use. I saw that B&O have a part number 6250031, but not sure whether this is correct – or available.
10 January 2023 at 13:47 #42664 GuyModeratorPart number 6250031 is a 5m cable with a DIN plug on each end.
I f you need 8 pin DIN to RJ45 you probably want this: (click for larger image)
EDIT: The type of PL cable that you need will depend on what equipment you are connecting. The above diagram is taken from the Beolink Handbook v1.9. If you let me know exactly what you are connecting and I will post the details.
10 January 2023 at 13:52 #42665Frog
GOLD MemberAh, so the part number is wrong.
basically, I’m just trying to find out what cable is used – in the diagrams I’ve seen for straight rj45 to rj45 powerlink, it looks like standard Ethernet cable (but probably cat6 or higher.
10 January 2023 at 14:11 #42667Frog
GOLD MemberThanks!
looks like cat6 STP will do the job.
10 January 2023 at 17:03 #42668NQVHNWI
BRONZE MemberGreat minds.
Im currently working through this and making my own custom cables for the Theatre Height Surrounds. Ive opted for CAT7 /Class F which is the B&O standard.
This is some background reading.
10 January 2023 at 17:49 #42669 Severed_hand_of_skywalkerBRONZE MemberYou have to use SHIELDED cables or it will get lots of interference.
Honestly I wouldn’t put yourself through the trouble. I got dirt cheap Shielded cat 7 cables on amazon and they work perfectly.
10 January 2023 at 18:19 #42670Frog
GOLD MemberThat’s what STP means. Cat 7 looks a lot like ML cable with less strands.
11 November 2025 at 14:17 #71065 RavstedBRONZE MemberHi,
I made a cable for Beovision 11 and Beolab 3 today using the below diagram.
I did it slightly different, but it seems to work without any issues.
However, I would like to understand the consequences of the change I made.
DIN PIN 2 (signal ground) > RJ45 PIN 3 (signal ground) & RJ45 PIN 7 (signal ground)
DIN PIN 2 (signal ground) > DIN PIN 7 (data ground)
DIN PIN 3 (audio L) > RJ45 PIN 8
DIN PIN 5 (audio R) > RJ45 PIN 6
I did not solder the RJ45 shield to DIN PIN 7
Instead I shorted DIN PIN 2 and DIN PIN 7
Reason… simply because I could not solder the material/wire of the RJ45 cable. The solder would not stick.
Any feedback on this approach – explaining the consequences.
Thanks.
11 November 2025 at 19:53 #71093 TignumGOLD MemberHi Ravsted,
Not sure about the shorting, it does not sound logical tbh, as in all pinouts they are kept separate.
FYI I went the other way: I did cut a few DIN-DIN PL cables in two, and crimped RJ45s to the cut ends. Finicky but I hate soldering!
Regards,
Johan
11 November 2025 at 20:24 #71094 RavstedBRONZE MemberHi,
thanks for your reply.
In the meanwhile I consultet chatgpt and it seems like I wont get the proper shielding.
I took the DIN connector apart again and managed to crimp a short cobber lead to the RJ45 shield and solder it to PIN 7 as specified.
But thanks for your tip.
Ravsted.
