Home Forums Product Discussion & Questions BeoVision Power socket input at back of 7-32 Beovision – where is it??
Viewing 6 posts - 1 through 6 (of 6 total)
  • #58543
    Barbicanduck
    I can’t find the power socket for the B&O 7-32 Beovision that a TV installer took off the wall when we installed our new TV. He took all the cables away also. I plan to sell the B&O now but need to ensure it’s still working. ย Can anyone help?
    #58551
    Guy
    View from rear, top edge of left panel, connector inserted upwards – hope this helps!
    (EDIT:ย  It’s a standard figure of eight (C7) power cable)
    My B&O Icons: No description available No description available No description availableNo description availableNo description availableNo description available No description available No description availableNo description availableNo description availableNo description availableNo description availableNo description availableNo description available
    #58553
    Barbicanduck
    Thank you, Guy. Life is so complicated enough, why they need to hide it like that, I don’t know and don’t get me started on the remote control!
    Thanks again.
    No wonder I couldn’t see it.
    #58560
    Guy
    Thank you, Guy. Life is so complicated enough, why they need to hide it like that, I donโ€™t know and donโ€™t get me started on the remote control!
    After using it for nearly 20 years, the Beo4 is now the only remote that doesn’t confuse me!ย  ๐Ÿ˜€
    #66360
    Andrew Adams-Smith
    Hi Guy,
    I have found in storage a Beovision 7 and I am working to get it functioning again. ย The pics show all the cables I have, what else do I need and how do I plug it into the wall power socket? ย Thanks
    #66373
    Guy
    Hi Andrew and welcome to Beoworld!
    I think that your best bet is to find the user manuals for the TV and work through the first time setup.ย  I can’t read the label in the picture, hence can;t be sure what version your TV is – there were several mks (at least 1 to 5).ย  If it’s a 7-32 then this B&O link tells you how to work out the version and has some of the manuals:ย  https://support.bang-olufsen.com/hc/en-us/articles/360041950211-Beovision-7-32
    Be aware that the TV may not be fitted with a tuner that is compatible with modern TV transmissions in your country of use.ย  (eg here in UK TVs need a digital DVB-T or DVB-T2 tuner, and these may not be fitted in early BV7s)
    Your first photo shows the power lead connected at the top – the same as the circled power connection in my photo earlier in the thread.
    I think the white cable is connected to the powerlink socket, which would normally supply a Beolab speaker that would sit on the bracket in your second photo (but I am not sure why the cable appears to change colour to black!
    Have a good look in the documentation and ask back here if anything is unclear.
