Home Forums Product Discussion & Questions BeoGram Polishing Beogram dust cover
  • #66282
    moonlight70
    Ha anyone found the ultimate solution for polishing a Beogram dust cover? I have tried wet sanding, both by hand and machine (1200 – 3000), and machine polishing pads with compound. But I haven’t manages to get rid of those thin scratches.
    • This topic was modified 1 day, 15 hours ago by moonlight70.
    #66321
    Glitch
    There are some tips in this older thread.
    https://forum.beoworld.org/forums/topic/polishing-beogram-dustcovers/
    The techniques mentioned work well. Better results will come with practice and patience.
    Posting some pictures of your specific cover/scratches will enable people give you better advice. Also, a detailed description of the equipment and supplies that you are using would be helpful.
    Glitch
