Home › Forums › Product Discussion & Questions › BeoGram › Polishing Beogram dust cover
- This topic has 1 reply, 2 voices, and was last updated 9 months, 1 week ago by
Glitch.
10 June 2025 at 18:48 #66282
moonlight70
BRONZE MemberHa anyone found the ultimate solution for polishing a Beogram dust cover? I have tried wet sanding, both by hand and machine (1200 – 3000), and machine polishing pads with compound. But I haven’t manages to get rid of those thin scratches.
12 June 2025 at 13:54 #66321Glitch
BRONZE MemberThere are some tips in this older thread.
https://forum.beoworld.org/forums/topic/polishing-beogram-dustcovers/
The techniques mentioned work well. Better results will come with practice and patience.
Posting some pictures of your specific cover/scratches will enable people give you better advice. Also, a detailed description of the equipment and supplies that you are using would be helpful.
Glitch
