Home Forums Product Discussion & Questions BeoSound PLEX dlna to Beosound 5 Encore
  • #61296
    sakis_s
    Has anyone managed to connect a PLEX dlna server to a beosound 5 Encore?
    My unit discovers the server without issues but when i go to N. MUSIC, it just appears a blank screen with no songs at all. No loading, nothing.
    Screenshot:IMG_0083
    Any ideas to try?
    My PLEX dlna settings are the default:
    Screenshot:
    Screenshot 2024-12-02 222424
    #66524
    MJBeo
    GOLD Member
    Not really and I am struggling actually with it again today, so I found my own old threads about it:
    https://archivedforum2.beoworld.org/forums/t/44513.aspx
    And minimserver also does not work
    https://archivedforum2.beoworld.org/forums/t/9629.aspx
    I have a Synology NAS so twonky is not supported as app, and needs to be installed with ssh so it breaks every now and then when I update.
    I was hoping someone would make a plex ‘DLNA client preferences’ txt file that you upload there in the screen you show and that works for everyone with the encore…
    #66526
    Carolpa
    I disagree!
    I use Minimserver for several years now. It is seen by all my B&o and yes, also by my Beosound 5 Encore.
    Plex I rejected in the past as music server. So I have no knowledge anymore about the correct settings.
    EDIT: Does the “DLNA default protocol info” contain music protocols? It shows (but the box is short….) only video protocols.
    • This reply was modified 2 days, 12 hours ago by Carolpa.
    #66534
    MJBeo
    GOLD Member
    Interesting, which hardware are you running minimserver on? Perhaps for context I need to mention that I am running the applications and the music on a Synology NAS, where the minimserver app is available in the package center. That one did not work for me before. The default media server from Synology does not work well either. Perhaps DSM 7.x has a better version, I am still on DSM 6.x
    #66558
    Carolpa
    For the moment and the longest time it is running on Windows. But some years ago it did run on MacOS and I did some testing with Linux (Raspberry Pi) in the past.
