Home › Forums › Product Discussion & Questions › BeoSound › PLEX dlna to Beosound 5 Encore
- This topic has 4 replies, 3 voices, and was last updated 9 months, 3 weeks ago by
carolpa.
2 December 2024 at 20:24 #61296
sakis_s
BRONZE MemberHas anyone managed to connect a PLEX dlna server to a beosound 5 Encore?
My unit discovers the server without issues but when i go to N. MUSIC, it just appears a blank screen with no songs at all. No loading, nothing.Screenshot:
Any ideas to try?
My PLEX dlna settings are the default:
Screenshot:
19 June 2025 at 15:12 #66524 MJBeoGOLD MemberNot really and I am struggling actually with it again today, so I found my own old threads about it:
https://archivedforum2.beoworld.org/forums/t/44513.aspx
And minimserver also does not work
https://archivedforum2.beoworld.org/forums/t/9629.aspx
I have a Synology NAS so twonky is not supported as app, and needs to be installed with ssh so it breaks every now and then when I update.
I was hoping someone would make a plex ‘DLNA client preferences’ txt file that you upload there in the screen you show and that works for everyone with the encore…
Favourite Product: Master Control Panel
19 June 2025 at 18:25 #66526 carolpa
BRONZE MemberAnd minimserver also does not work
I disagree!
I use Minimserver for several years now. It is seen by all my B&o and yes, also by my Beosound 5 Encore.Plex I rejected in the past as music server. So I have no knowledge anymore about the correct settings.
EDIT: Does the “DLNA default protocol info” contain music protocols? It shows (but the box is short….) only video protocols.20 June 2025 at 07:27 #66534 MJBeoGOLD MemberInteresting, which hardware are you running minimserver on? Perhaps for context I need to mention that I am running the applications and the music on a Synology NAS, where the minimserver app is available in the package center. That one did not work for me before. The default media server from Synology does not work well either. Perhaps DSM 7.x has a better version, I am still on DSM 6.x
21 June 2025 at 05:17 #66558 carolpa
BRONZE MemberInteresting, which hardware are you running minimserver on? Perhaps for context I need to mention that I am running the applications and the music on a Synology NAS, where the minimserver app is available in the package center. That one did not work for me before. The default media server from Synology does not work well either. Perhaps DSM 7.x has a better version, I am still on DSM 6.x
For the moment and the longest time it is running on Windows. But some years ago it did run on MacOS and I did some testing with Linux (Raspberry Pi) in the past.
