Home › Forums › Product Discussion & Questions › BeoGram › Playing a Beogram 5005 via 7 pin female to RCA
- This topic has 5 replies, 4 voices, and was last updated 3 years, 9 months ago by
Steve at Sounds Heavenly.
27 May 2022 at 12:28 #35046
Cavscout
BRONZE MemberI purchased a few 7 pin female to male RCA adapters to test a Beogram 5005 turntable that I acquired.
So I plugged in the 5005 male connector into the female adapter and then the male RCA into my phono stage input on my (confirmed working) amplifier.
But I get NO MUSIC …just a hum that is consistent with the volume.
Because I ordered a few of the adapters I figured I would try another…same problem.
Does anyone know what could be wrong here ?
The 7 pin connectors only connect one way and I have confirmed that I have it hook up correctly.
Any guidance is greatly appreciated
Thank you
27 May 2022 at 13:58 #35047 KolfMAKERBRONZE MemberHi Cavscout,
How sure are you that the leads in your cable(s) are connected to the right pins?
Do you have a scheme of the connections, and where did you buy them? (Did you contact Steven from SoundsHeavely?)Location: The Netherlands
27 May 2022 at 15:34 #35048Cavscout
BRONZE MemberHi kolfMAKER
I am not at all sure if they are connected to the right pins as the connector only fits one way.
Here is what I bought.
GLHONG MIDI Din 7 Pin Female to Dual RCA Male Professional Grade Audio Cable for Bang & Olufsen, Naim, Quad.Stereo Systems (1.5 Meter) https://www.amazon.ca/dp/B07W1PKMRQ/ref=cm_sw_r_apan_i_19KTVQ6MH7KAD4CZXXZW
I don’t know SoundsHeavily
27 May 2022 at 15:39 #35049 GuyModeratorDoes anyone know what could be wrong here ?
The cable could be wired for the signal to go in the opposite direction. Have a look at the diagrams here – schematics 7 and 8 may explain the problem (albeit you need to imagine a female DIN): https://www.hifi4all.dk/forum/forum_posts.asp?TID=32157&PN=1
EDIT: The cable that you have bought is for an input into a DIN-equipped B&O amplifier – hence wrong direction. You need one like this: https://soundsheavenly.com/beogram-record-players/14-2244-beogram-to-non-bo-device-phono-pre-amp-receiver-amplifier-etc.html#/2-length-1m/60-grounding-internal_ground_link
27 May 2022 at 19:24 #35050Cavscout
BRONZE MemberThanks but that was a video.
Where is the price for the cable and for shipping ?
Do you have that link ?
Thank you
27 May 2022 at 19:47 #35051 Steve at Sounds HeavenlyGOLD MemberHi Cavscout,
Thanks for your enquiry. If your amplifier has a built in phono pre-amp, then you just need this cable to connect it to the phono input of the amplifier:-
If the amplifier doesn’t have a pre-amp, you will need this pre-amp kit instead, which comes with all cables needed and full instructions, ready to “plug and play”:-
https://soundsheavenly.com/beogram-record-players/12-2196-pre-amp-bundle-for-bo-beogram-and-all-turntables.html#/36-output-5_pin_din_aux/41-power_supply-uk – please choose the “Twin RCA plugs” output option for your amplifier.
If you are unsure about whether the amplifier has a built-in pre-amp, please email me the full model number and I will be pleased to confirm this.
Kind regards, Steve from Sounds Heavenly.
