Home › Forums › Product Discussion & Questions › BeoVision › Picture in picture bt. hdmi 1 and hdmi 2? on BV11
- This topic has 8 replies, 2 voices, and was last updated 3 years, 6 months ago by
master123456789.
8 August 2022 at 04:53 #36769
master123456789
BRONZE MemberHi forum
Normally picture in picture is between tv-tuner and hdmi. Is it possible to make picture in picture between hdmi1 and hdmi2? Is says “combination not possible” but maybe you know a fix? Becouse I think technically it must be possible.
It is on a Beovision 11.
9 August 2022 at 15:57 #36770master123456789
BRONZE Memberno one uses picture in picture??
10 August 2022 at 02:48 #36771jvezina
GOLD MemberHow many HDMI inputs the TV has? For the Beovision 7, the picture-in-picture works between HDMI 1 and 2 and 3 and 4. This is because the two adjacent HDMI sockets are selected by a simple switching IC and only one input signal goes to the video processor. HDMI 3 and 4 are also selected with a switching IC but a second input signal line goes to the processor, making PIP possible.
If the Beovision 11 has 4 HDMI sockets, the device you want to be used with PIP will have to be connected to HDMI 3 or 4.
17 August 2022 at 16:15 #36772master123456789
BRONZE MemberBV11 the mk2 as I have – has 6 hdmi. 5 in a row back, and the number 6 at the top.
Maybe I can try with the one at the top.
17 August 2022 at 16:25 #36773master123456789
BRONZE MemberI have tried some combinations with the hdmi 6 on the top and others – nothing helped. Maybe some know a combination?
19 August 2022 at 16:39 #36774jvezina
GOLD MemberThe valid combinations are described in the user manual. If you have lost yours, the B&O website should still have a downloadable copy.
Good luck,
Jean
23 August 2022 at 16:19 #36775master123456789
BRONZE MemberHere are the manual – can you find where it is? Would be very nice, thank you. 🙂
24 August 2022 at 00:10 #36776jvezina
GOLD Memberhttps://bangolufsenassistentgohe.blob.core.windows.net/manuals/TELEVISIONS/BEOVISION_11_WITH_BEO4/en-1310-en-beovision-11-eu-web.pdf Here are the manual – can you find where it is? Would be very nice, thank you.
I just checked, and unfortunately picture in picture doesn’t work with two HDMI sources.
From page 28:
“There are some limitations when using the Picture-and-Picture (P-AND-P) function since some source combinations may not be possible. For example, you cannot watch two HDMI sources or two coded channels at the same time. When an invalid combination is selected, an on- screen message appears on the television screen.”
It was possible on a Beovision 7 using the Beosystem 3 platform, but that functionality was dropped for the Beovision 11.
24 August 2022 at 13:18 #36777master123456789
BRONZE MemberThank you – what a BIG mistake on bv11. Also as far as I know BV11 also uses beosystem 3, but as you say, this seem dropped.
