Home › Forums › Product Discussion & Questions › BeoSound › Options Beosound 4 connected to BeoSound 5 via Masterlink
- This topic has 1 reply, 2 voices, and was last updated 18 minutes ago by
Guy.
24 September 2026 at 10:19 #125645
Juergen kress
BRONZE MemberHi Experts
Want to connect my BeoSound 5 to my BeoSound 4 via Masterlink cable (in separate rooms). Which options do I need to choose please?
Thanks Jürgen
25 September 2026 at 12:50 #125655 Guy
ModeratorI put this in the configuration tool and suggest the following:
Try the BS5 in A.OPT 1 – I think it should auto-configure.
And the BS4 in A.OPT 6.
But the Config Tool does also say that if you want the BS4 to be the ‘audiomaster’ and only use BS5 for N.MUSIC/N.RADIO, then audiomaster YES/NO must be set to NO on the BS5 which then disables its OPTION settings. I hope this makes sense!
