Home › Forums › General Discussion & Questions › General Discussion & Questions › oneRemote backup battery?
- This topic has 4 replies, 3 voices, and was last updated 2 hours, 2 minutes ago by
patcherley.
30 July 2025 at 19:24 #68048
patcherley
GOLD Member30 July 2025 at 21:40 #68049GOLD MemberNever heard that the device should have a backup battery.
But it is not unknown, that it looses its settings.
You will have to set it up again.If you want a 100% answer, you could contact OneRemote directly.
Location: Flensborg————Danmark30 July 2025 at 22:44 #68050patcherley
GOLD MemberThanks will continue to reset
Location: Hampshire My B&O Icons:31 July 2025 at 09:53 #68063ModeratorI have taken mine to pieces (to repair a loose connection) and there is definitely no backup battery, so you will have to set it up again according to the instructions.
EDIT: Attached is a pdf of the instructions in case you don’t have them.
This reply was modified 6 hours, 42 minutes ago by
You must be logged in to view attached files.Location: Warwickshire, UKMy B&O Icons:31 July 2025 at 14:50 #68077patcherley
GOLD MemberThanks Guy, have the instructions but a spare copy on the site is always useful.
