Home › Forums › General Discussion & Questions › General Discussion & Questions › Non-B&O record player
- This topic has 6 replies, 3 voices, and was last updated 2 years, 7 months ago by
MikeNewman.
25 August 2023 at 07:11 #48473
MikeNewman
BRONZE MemberI have been given a Beomaster 5500 and pair of passive Penta speakers (the Beogram I was also given is in poor condition) and I wish to connect my Sony record player. This is currently only possible using Bluetooth, a receiver and the Tape / Aux socket but I would prefer to used a wired connection. I’ve tried the various phono sockets with no success in spite of my turntable having a pre-amp. Am I missing something? Thank you.
26 August 2023 at 08:01 #48474Dillen
ModeratorIt should connect to the Phono input. Either the DIN or the RCA sockets.
Then select Phono as the source on the Beomasters remote.
If no sound is heard from the record player (and the Beomaster will play radio etc. fine), there must be a problem with either the record player, the cable/adapters or the Beomasters phono input.Martin
26 August 2023 at 08:11 #48475MikeNewman
BRONZE MemberThanks Martin. I’ll give it another try. Mike
26 August 2023 at 08:30 #48476Dillen
ModeratorWhat cable/adapter are you using?
26 August 2023 at 11:57 #48477olivierc
BRONZE MemberI’ve tried the various phono sockets with no success in spite of my turntable having a pre-amp.
Here’s an excerpt from the BM5500 Manual from the B&O repository.
The RCA cables should connect to the PH sockets, maybe the Preamp should be turned off.
The BG5500 did not have an internal preamp, therefore I assume the Phono signal (regardless if connected via DIN or RCA) is routed to the BM5500 internal RIAA preamp.
Regards.
Olivier
PS and OT: wondering what the PRE AMP connections are meant for.
26 August 2023 at 14:35 #48478Dillen
ModeratorWill your Beomaster play radio or any other source?
If your record player has a preamp, and it is active, you could try connecting to the TP2 inputs and select TP2 as the source on the Beomaster.The PRE-AMP sockets are outputs from just before the internal power amplifier. For using an external amplifier.
26 August 2023 at 17:10 #48479MikeNewman
BRONZE MemberThanks Dillen, Olivier & Martin. It’s now sorted. I re-examined my cables and they had not been set up correctly. Best wishes. Mike
