Home › Forums › General Discussion & Questions › General Discussion & Questions › no s/n in firmware, devices invisible to NL-Hardware
- This topic has 7 replies, 3 voices, and was last updated 4 months ago by
Jelop.
29 April 2022 at 02:32 #34416
Nihil
BRONZE MemberHi,
i‘m having some trouble with 2 devices, having the same problem, a Masterlink-Gateway and a Beosound Essence MK2.
Both devices show the s/n 00000000 in its firmware.
They are not found by the B&O-App for setup.
Does anybody know if there are batteries inside (like cmos-batteries in pcs) that could be the cause?In general both devices seem to work correctly, the essence can be used with bluetooth, dlna or airplay without problems.
MLGW can be configured completely and is found by the Beolink2-App on ios.The web interface of both devices can be accessed and used completely.
The essence does not upgrade the firmware to the latest, i think because of the missing s/n causing problems in identifying the hardware online.
Manual software update is not possible as B&O does not give acces to the firmware-file.
Has anybody had the same or similar problems with these or different devices or knows where to get the firmware files?
Hope for some useful hints, thanks in advance
1 June 2022 at 14:24 #34417LabFiftyFan
BRONZE MemberI am having exactly the same issue with my recebtly acquired s/h Essence MK2. Can set it up as an AirPlay 2 speaker, can connect via bluetooth, can view the web interface for it but it refuses to be deteced by the B&O app.
Serial number also shows as 00000000
If anyone has any ideas or suggestions then I’d love to hear them.
1 June 2022 at 15:04 #34418Nihil
BRONZE MemberHi, meanwhile I figured out (info from local b&o-dealer) that new mainboards/devices come with serial 00000000, the correct serial has to be set with a configuration tool by the dealer/technican who changed the board.
He said that this can only be done once. So there are 3 options now:
– our devices got a new board and are not yet configured
– our devices got a new board and the person who changed it made an error in configuring, so it it not possible to enter the correct serial from now on
– our devices have a defective chip where the serial is stored (as all other settings are kept in memory after losing power maybe there is a special chip for the s/n)
I will go the dealer in the next 3 weeks and give it a try to enter the correct serial.
1 June 2022 at 16:11 #34419LabFiftyFan
BRONZE Member@Nihil Thanks for the follow up; This is very interesting. I am hoping to get to a dealer this weekend so will take this knowelge with me; I really hope it wil be possible for us to fix our devices.
1 June 2022 at 16:36 #34420Nihil
BRONZE Member6 June 2022 at 08:54 #34421LabFiftyFan
BRONZE MemberI took my Essence MK2 to a dealer on Saturday, they tested the unit and confirmed that it could be streamed to. They said that they had seen the missing serial number issue before and that there was indeed a fix.
I was provided with a PDF which contained a link to a new firmware that would enable the serial number to be recovered along with instructions as to how to install this; essentially this involves connecting to the units built in wireless access point and uploading the new firmware.
Sadly this is hasn’t worked for me and the update process fails. I have tried doing this whilst connected to the unit via wifi where the update fails at 99% and via ethernet where the update fails at anywhere between 40-60%.
I spoke with B&O support via phone and they have followed up this morning suggesting that unit needs to go back to a B&O technician for further diagnosis.
The adventure continues…
6 June 2022 at 13:49 #34422Nihil
BRONZE MemberHi again, sounds not very good but maybe it is a good step forwards.
I contacted you via p/m
8 December 2025 at 22:53 #71817Jelop
BRONZE MemberI know it’s been three years, but were you able to solve the problem? I have exactly the same issue. Do you have a firmware file that could be updated?
