Home › Forums › Product Discussion & Questions › BeoLink › NL/ML converter to connect to MasterLink
- This topic has 2 replies, 2 voices, and was last updated 1 month, 3 weeks ago by
Michiel Borchers.
17 March 2025 at 18:59 #64553
Michiel Borchers
BRONZE MemberHello Beoworld,
Great this forum!
Just bought a nl/ml converter to connect my ML gear to Essence MKII.
My setup :
Living room
–ย ย ย ย ย ย BV10 with BL8000 PL; ML to Distributor box Video connected
–ย ย ย ย ย ย BeoSound 3000 ML connected to Distributor Box Audio connected. Used for CD and radio
–ย ย ย ย ย ย BS Essence MKII connected to DVD on BV10; used for digital radio and digital music
–ย ย ย ย ย ย ML/NL converter not yet connected
Link room (annex Living room)
–ย ย ย ย ย ย BL3500 ML from distributor box Link 1
Link room 2 (annex Living room)
–ย ย ย ย ย ย BL3500 ML from distributor box Link 2
I’ve read several posts on MLC; what I don’t understand from which source a ML cable should be connected to MLC?
17 March 2025 at 21:31 #64556ModeratorHi and welcome to our friendly forum!ย Hopefully we can help you get set up and connected.
To answer your question about which ML source should connect – it doesn’t matter!ย In a masterlink setup all the masterlinked components are connected in parallel – effectively they all share the same connections.ย If you have a spare socket on the distribution box then you can connect to the NL/ML converter from that.
I think that when you come to set up the NL/ML Converter, you will have to set it up as ‘Source Centre’ because you already have a Videomaster (the BV10) and an audiomaster (the BS3000) on your ML system.ย ย However, my experience on NL/ML Converters is quite limited so please have a read of the setup manual (do you have it?) and try to work out what is best for you.ย I am sure that other forum members will be able to advise further.
Good luck!
Location: Warwickshire, UKMy B&O Icons:17 March 2025 at 21:56 #64558Michiel Borchers
BRONZE MemberThank you for your quick response.
The receiver is on its way to me; as soon as I’ll have it I will set it up like this. -
