Home › Forums › Product Discussion & Questions › BeoLab › NL/ML access
- This topic has 5 replies, 3 voices, and was last updated 2 months ago by
carolpa.
14 August 2026 at 13:50 #124971
Bob Avery
BRONZE MemberI have been advised to change a config file in my NL/ML Converter by B&O Support. They suggest finding the converter IP address and accessing the settings page using a web browser via a laptop but this does not work.
I need to change the sources linked to the TV command as I have removed Sky HD from the system and the BeoLab soundbar upstairs forces the TV to try to activate HDMI 1 for Sky – but Sky isn’t there anymore and as a result we get no sound from the Soundbar until I go back downstairs and select Live TV.
If anyone can point me in the right direction I would be grateful!
14 August 2026 at 13:57 #124972 Tignum
GOLD MemberHello Bob,
The NL/ML converter can be configured with any computer. You can access it like this (from the manual that you best get a copy of!).
‘Connection via an Internet Browser: Enter BLC- followed by the BeoLink Converter NL/ML serial number: [BLC-XXXXXXXX.local].’
Regards and good luck, Johan.
14 August 2026 at 14:23 #124973Bob Avery
BRONZE MemberHi Johan
I did try ‘BLC-XXXXXXX.local’ but get no response.
Using mac terminal app I have tried ping ‘BLC-XXXXXXXX.local’, this resolves to an IP address but the pings just timeout.
14 August 2026 at 14:33 #124974 Tignum
GOLD MemberHello Bob, instead of the XXXXXXX, you do use the serial number (that is printed on the label on your NL/ML converter), right? Just to be sure :-).
14 August 2026 at 14:37 #124975Bob Avery
BRONZE MemberHi Tignam
I can’t see any serial number without taking the device off the rear of the TV, soon as I get a chance to do this I will have a look and see what happens.
The serial number I’m using at the moment I’m getting from a network scanner via my EERO mesh app.
15 August 2026 at 05:08 #124987 carolpa
BRONZE Memberor you use the IP address of the BLC.
Be sure your Mac or PC is connected to the same network as the BLC
