Home › Forums › Product Discussion & Questions › BeoSound › New Software Edge/Shape/Core/BS1/BS2/A9 (mk3/4)
- This topic has 36 replies, 16 voices, and was last updated 2 years, 6 months ago by
Tignum.
31 October 2022 at 02:31 #40341
LeMirage
BRONZE Memberwho dared? My Edge is stable and no complaints, so a little hesitant…. 😉
Software 2.1.50871 – Release date 26th October 2022
Enhancements:
– Improvements to network stability
– AirPlay 2 improvements
– Spotify Connect improvements
– General bug fixes
1 November 2022 at 17:54 #40342Stan
BRONZE MemberNot available to me in the US yet. It’s always a bit of a roll of the dice, but I don’t think there’s been a “bad” release in a few years. I will probably upgrade when I am able.
1 November 2022 at 18:21 #40343 carolpaBRONZE Memberwho dared? My Edge is stable and no complaints, so a little hesitant….
Software 2.1.50871 – Release date 26th October 2022 Enhancements: – Improvements to network stability – AirPlay 2 improvements – Spotify Connect improvements – General bug fixes
my BS Shape has this version…… until now no issues.
note: the A6 and BS35 have the (beta) version since some time 2.1.50399 installed. Both work as supposed. The BS35 has a strange phenomenon: the display keeps displaying “visible as…” after a disconnection from the mains. This is solved by doing a factory reset and reinstall the settings.
addition: the M3 has v2.1.50872
2 November 2022 at 10:18 #40344LeMirage
BRONZE MemberAlthough I wrote that my Edge is stable Spotify connect actually can use some improvement. Selecting the Edge sometimes takes 2 of 3 attempts before it starts playing. And since Spotify connect improvements are mentioned I will give this update a go and report back here.
2 November 2022 at 12:13 #40345 TignumGOLD MemberMy Core is running 2.1.50871, no issues experienced.
2 November 2022 at 17:09 #40346Mbee
BRONZE MemberThe changelog seems quite limited for a big version step up (from 1.x to 2.1)!
On my side it seems that the volume wheel on the B&O app has finally been « recalibrated » so that the volume is not high just after the middle of the wheel.
2 November 2022 at 21:55 #40347 Rolf2GOLD MemberFor my Essence MK II an update was in the app this evening and it is now on 2.1.50867. I do not know what the update has changed. Although I have the „automatic update“ function enabled, I had to trigger it manually. I will keep an eye on it.
Beosound 2 updated as described in previous post to 2.1.50871. Emerge is still on 1.8.10017.
Favourite Product: BeoSystem 4500
3 November 2022 at 01:46 #40348 Severed_hand_of_skywalkerBRONZE MemberMy A9 Mark II also got an update today.
6 November 2022 at 17:51 #40349Alsfeld
BRONZE MemberMy dream became reality !!! 🙂 🙂 🙂 !!!
Unbelievable, with the software update 2.1.50867 my two Beosound 35 are now displaying the title and artist when streaming via Airplay at the Beosound 35 display as well as at the B&O app. So far it only displayed “AirPlay”.
It took Bang&Olufsen more than 6 years to realize this feature!
I use Roon Labs and stream via Airplay from my Roon Core to my loudspeakers. I really enjoy that my Beosound 35 are displaying the current song, now. A really nice feature.
I started to think about purchasing some more Beosound 35’s (even it is discontinued) to replace some non-B&O speakers.
6 November 2022 at 18:27 #40350beoandy
BRONZE MemberI also think the behavior of the join command (beo4 and BLI/BLGW) has changed with 2.1.50867.
before 2.1.50867 you could join a running source from the link-room, and if there was none running, the last selected local source was played.
after 2.1.50867, the last selected local source is not played (if no source is playing in the link- room). – you can´t start the system with the beo4 join command without a running link-source.
beoandy
6 November 2022 at 18:55 #40351 TignumGOLD MemberSwitching radio stations on the Core through Beo4 and MasterLinked products (using a BLC) did not work a couple of times now. After changing the radio station in the app however, it does work as normal. I will see if this persists and if I can replicate and influence and let you know. I did restart the Core and deleted and rejoined both the Core and the BLC to no avail.
8 November 2022 at 10:32 #40352mbolo01
BRONZE Memberafter 2.1.50867, the last selected local source is not played (if no source is playing in the link- room). – you can´t start the system with the beo4 join command without a running link-source.
This may be related to “Classic UI” being disabled in app settings/Beolink.
8 November 2022 at 13:51 #40353 trackbeoBRONZE Member“May”? be related? What [else] does that setting do?
Could someone please actually test this with their ASE2 device, for example a BeoSound1(2gen), with a local source, for example a local UPnP/DLNA server playlist/queue? It used to be that tapping the top would, if no other source was playing, beep once, then pick up where it left off in the previously-paused local source.
8 November 2022 at 15:22 #40354mbolo01
BRONZE MemberI’m used to “tap/press to join” with my older Beolink devices (BS 1, M5, M3, Core + Essence Remote), or, when no other source is playing, resuming a local source.
If the Classic mode is disabled, this no longer works (i tested it), a tap/press starts a local source instead and documentation says that a long press is required to join which not all device can do, e.g. BS 1.
Also, I’m used to uses long press where supported to shutdown all devices. Reason why I kept Classic mode enabled.
9 November 2022 at 16:14 #40355beojeff
BRONZE MemberAfter the updates, I’ve found the following:
- My Beoplay A6 can again pair with a remote. It had lost that ability to pair for many months.
- A BLI macro firing a standby command on the Beosound 35 is acting really weird. Firing the macro puts the speaker into standby for just a moment and then automatically re-joins a playing source.
- The update caused the customized My Buttons on the Beoremote One to be lost and they need to be programmed again.
- The update caused some of the LIGHT commands on the Beoremote One to become hidden.
10 November 2022 at 08:13 #40356 TignumGOLD MemberSwitching radio stations on the Core through Beo4 and MasterLinked products (using a BLC) did not work a couple of times now. After changing the radio station in the app however, it does work as normal. I will see if this persists and if I can replicate and influence and let you know. I did restart the Core and deleted and rejoined both the Core and the BLC to no avail.
I found out that after a full system switch-off (in the app, or with a long press on the Beo4) the issue arises: when I then choose RADIO on the Beo4, the last chosen radio station plays, but I cannot use the Beo4 to choose another station. Only after I change radio station in the app once, I can use the Beo4 again for changing stations (I use TuneIn btw). I will see if I can report this to the software team.
Is anyone else seeing this too?Location: Netherlands
14 November 2022 at 09:32 #40357SaltineSurfer
BRONZE MemberSwitching radio stations on the Core through Beo4 and MasterLinked products (using a BLC) did not work a couple of times now. After changing the radio station in the app however, it does work as normal. I will see if this persists and if I can replicate and influence and let you know. I did restart the Core and deleted and rejoined both the Core and the BLC to no avail.
I found out that after a full system switch-off (in the app, or with a long press on the Beo4) the issue arises: when I then choose RADIO on the Beo4, the last chosen radio station plays, but I cannot use the Beo4 to choose another station. Only after I change radio station in the app once, I can use the Beo4 again for changing stations (I use TuneIn btw). I will see if I can report this to the software team. Is anyone else seeing this too?
I’ve discovered that I cannot use the number pad in a link room after joining. For example, if I join TuneIn that’s playing on my M5 and join my A9 mk4 to it, I can’t select presets using the number pad on the BR1 (BT) in the link room. This also means I can’t select the CD playing, or directly change FM radio station on my BS9000 via the NL/ML converter. I’m not sure if it’s an issue with the BR1 that’s also received a Firmware update, or the speakers.
14 November 2022 at 12:42 #40358 TignumGOLD MemberThat does not sound too unsimilar. Could you try to switch station once using the app, and see if it then works with BR1?
16 November 2022 at 03:28 #40359Anonymous
InactiveHi
another nice feature for the future (i.e. not top priority !) would be the availability to like a post
17 November 2022 at 20:08 #40360 TignumGOLD MemberSwitching radio stations on the Core through Beo4 and MasterLinked products (using a BLC) did not work a couple of times now. After changing the radio station in the app however, it does work as normal. I will see if this persists and if I can replicate and influence and let you know. I did restart the Core and deleted and rejoined both the Core and the BLC to no avail.
After some friendly e-mail exchange I received this answer: “We are pleased to inform you that yes it will be fixed in a future software update regarding the issue; the issue has been reported to the Product Development team, and they will provide a software update as soon as possible.”
