Home › Forums › Product Discussion & Questions › BeoRemote › New Halo firmware at last…. Version 1.5.930
- This topic has 29 replies, 11 voices, and was last updated 3 years, 4 months ago by
Severed_hand_of_skywalker.
20 April 2022 at 07:33 #34266
LeMirage
BRONZE MemberReleased yesterday! Gonna dust of my Halo again and hopefully more stable now. Was using bulletproof Essence remotes the last weeks because I got rather tired of the instable Halo wifi connection.
release notes from B&O support site:
Software 1.5.930 – Release date 19th April 2022
Features:
– Adds support for Beolab 90 and Beolab 50. You can now control your speakers using Beoremote Halo.
– Source list is now split up into Audio and Video sources.
– Increased stability20 April 2022 at 09:06 #34267 MillemisBRONZE MemberThanks!
Would be nice to see the Halo in action with the 90/50’s – to see which benefits that would bringin real life.
20 April 2022 at 09:31 #34268LeMirage
BRONZE MemberI think it’s a phased rollout, mine doesn’t fetch the new firmware yet…
20 April 2022 at 10:41 #34269NQVHNWI
BRONZE MemberInteresting.
When using my BL90s in “Audio” mode i.e. attached via XLR to my Auralic system (i.e. not controlled by a Beovision), I use the “BeoEye” IR receiver and an Essence Remote in IR mode. It works but is a little clunky and insensitive to volume control.
It will be interesting to see what the functionality of the Halo will be – whether it just uses IR or is true WiFi/BT control? Perhaps the more important aspect is the control of the BL90 being threshold triggered on/off by the Halo to enable instant switching from the Auralic to Beovision ecosystem?
Further, if the BL90 is getting Wifi/BT control (no sign in the BL90 firmware yet), then does that extend to BR1 being updated?
Interesting
21 April 2022 at 09:27 #34270LeMirage
BRONZE MemberAnyone installed the latest Halo firmware already? Mine doesn’t fetch it, contacted support and they haven’t figured out yet what is happening until now.
22 April 2022 at 12:29 #34271talisman
BRONZE MemberHi!
Has anyone managed to update their beoremote Halo to the latest version: Software 1.5.930 – Release date 19th April 2022 ?
22 April 2022 at 14:58 #34272LeMirage
BRONZE MemberSo it seems I’m not the only one unable to get it. Weird. And support doesn’t have a clue either yet, if the reason would be a (regional) phased rollout they probably would have know that?
23 April 2022 at 16:10 #34273Seanie
BRONZE MemberI got it last night
23 April 2022 at 19:18 #34274talisman
BRONZE MemberNow I have received Software 1.5.930 – Release date 19th April 2022 for my Beoremote Halo!
24 April 2022 at 07:18 #34275BeoZip
BRONZE MemberHere in Germany too.
24 April 2022 at 09:45 #34276LeMirage
BRONZE MemberIn the Netherlands nothing yet….
24 April 2022 at 17:12 #34277 carolpaBRONZE MemberIn the Netherlands nothing yet….
By switching of the auto-update and toggling from-to the software page, the update appeared. The first Halo is updating at the moment. (location NL)
25 April 2022 at 07:04 #34278LeMirage
BRONZE MemberStill nothing yet here…
25 April 2022 at 14:01 #34279BeoZip
BRONZE Memberso looks mine since Sunday
26 April 2022 at 20:20 #34280LeMirage
BRONZE MemberAny clear improvements?
my Halo on the older firmware looses wifi-connection about every 2-3 days. Only solution is rebooting the Halo , wifi router AND the devices the Halo is controlling. It’s beyond annoying.
26 April 2022 at 22:01 #34281 trackbeoBRONZE Member@LeMirage, you may already have tried this, but the typical response for certain “other” wireless music systems (coughSonosSneeze) is to assign static IP addresses in your Wi-Fi router for each and every system component, and move its DHCP base address higher than any of them. (And reboot everything afterward, plus make sure you have not assigned the same static IP addresses to anything else, of course.)
This absolutely should not be necessary — but consumer residential router firmware is sometimes as buggy as B&O’s. Especially across single devices being unplugged or the internet connectivity going down temporarily, this kind of thing “just happens”. It’s a pain, and you don’t know if it did any good until days later, but it’s worth a try.
4 May 2022 at 19:10 #34282LeMirage
BRONZE MemberFinally got the new firmware after return from holiday. Battery life has improved A LOT !!! Wifi stability testing in progress……
23 June 2022 at 21:17 #34283LeMirage
BRONZE MemberReally happy with this firmware, finally the table Halo has a useful battery performance now. With moderate use it holds up about five days in between charges. Very acceptable compared to the marginal 24-36 hours from previous versions.
still my Halo’s sometimes loose connection, but this problem seems to be in the Level and/or wifi router.
5 October 2022 at 11:55 #34284LeMirage
BRONZE MemberAnyone installed the new Halo firmware yet? I’m hesitant. Only change according release notes is added compatibility of the Theatre.
12 October 2022 at 03:31 #34285 Severed_hand_of_skywalkerBRONZE MemberI did. Seems to work ok. As far as Halo’s go that is.
