Home › Forums › Product Discussion & Questions › BeoLink › MLGW and BL3500
- This topic has 4 replies, 2 voices, and was last updated 3 years, 8 months ago by
Chris_101.
25 July 2022 at 11:41 #36329
Chris_101
BRONZE MemberHi All
I’m thinking about buying a Master Link Gateway, but it seems like in order to use it with BeoLab 3500 you need a firmware version 3.3 or higher, my BL3500 are firmware version 2.0 and I can’t find any PCB36 with FW 3.3, also I have 5 of them so it would be expensive.
Can someone confirm, that it won’t work with the lower FW versions before I buy a MLGW?
Best regards
Christian
25 July 2022 at 11:59 #36330 GuyModeratorDid you see this thread which may be helpful depending on your planned usage?
https://archivedforum.beoworld.org/forums/t/39994.aspx
25 July 2022 at 12:12 #36331Chris_101
BRONZE MemberNo I did not 😉 so thanks for the link. I need to use the home automation and macros, so as I read it the BL3500 needs to be updated.
Does anybody know if the PCB36 still can be bought?25 July 2022 at 12:17 #36332 GuyModeratorThe last post in that thread mentions B&O part number 8006039
Maybe give AVA Services a call and see if it is still available: https://www.avaservices.co.uk/
25 July 2022 at 12:22 #36333Chris_101
BRONZE MemberThanks ?
