Home Forums Product Discussion & Questions BeoGram missing BG4000
Viewing 20 posts - 1 through 20 (of 32 total)
  • #33028
    hcraig244
      Well…..here we go, first post is another episode in the continuing saga of the missing Beogram and its errant power supply….the doner machine turned upP1016717 (Copy)
      #33029
      hcraig244
        The replacement toroidal is a good fit dimensionally…..will fit above the fusebox nicely…P1016719 (Copy)
        #33030
        hcraig244
          230vac power cable and improvised fusebox connected up…..P1016723 (Copy)
          #33031
          hcraig244
            This is the data sheet for the transformer….yellow and black connected together to provide the 24v supply across orange and red to the 24vdc rectifier, connecting red and black (12v) to the 6vdc rectifier…..sounds straightforward enough 818By9byH9L._SL1500_
            #33032
            hcraig244
              just getting my head around the order of things here….I will try harder
              #33033
              hcraig244
                This is the data sheet for the voltage regulator…Untitled
                #33034
                chartz
                GOLD Member
                  Very nice and tidy Craig.
                  #33035
                  hcraig244
                    timestamp is a bit of a challenge here……my replies are all jumbled up, however wired up the transformer and powered up….slowly with the variac and watched the output of the 6vdc regulator it came up nicely…..and as i wound up the variac the output started to fall back to 0vdc….like a capacitor charging up?
                    #33036
                    hcraig244
                      This is how it looks, I have the regulator connected on leads to allow measurments to be taken easilyP1016726 (Copy)
                      #33037
                      hcraig244
                        This is the regulator 6vdc output under operating loadP1016727 (Copy)
                        #33038
                        hcraig244
                          However the 6vdc fell off when the regulator went into high temp cut off……it was getting very hot!….few measurements revealed that I am getting 24v at the input to the voltage regulator instead of the 12v i was expecting, the output from the transformer is 12v to the 6v rectifier…..
                          #33039
                          hcraig244
                            This is how the new power supply is tied in…supply
                            #33040
                            hcraig244
                              Ok…..cleaned the drawing up to include the actual transformer wiring details and took some measurements…..these are all with the turntable running and under normal load conditions…everything works fine though the voltage regulator gets hot…put a heat sink on it which helps quite a bit.supply3
                              #33041
                              hcraig244
                                This looks like an issue with the centre tapped transformer, I have read on the internet that a common neutral on the DC outputs of dual supplies of different voltages fed from centre tapped transformers are not allowed, this may be my problem.
                                When I disconnect the 24vac supply from the transformer to the 24vdc rectifier I get the expected 12vdc from the output of the 12vdc rectifier, so I know the 12vdc rectifier is working fine..I have no problems with the 24vdc side which is working fine, as this is the required higher supply im not surprised.  I cant see anything untoward except the common neutral to both rectifiers……..any advice regarding this would be welcome, as always ;¬)
                                #33042
                                hcraig244
                                  moving on…..got the dual outputs from the centre tapped transformer sorted out, after a good deal of head scratching….and glasses of wine! I removed the 6vdc bridge rectifier and reinstalled the smoothing capacitor, output from the centre tap connection of the transformer to the input of the new regulator and now get a decent full wave rectification.
                                  cant seem to get a jpeg loaded……..maybe later
                                  #33043
                                  hcraig244
                                    this is the input to the new voltage regulator from the centre tap of the the transformer, much improved though still a little high, this measurement was taken under load, this was previously sitting at 24v
                                    P1016745 (Copy)
                                    #33044
                                    hcraig244
                                      This is the current wiring detail I have implemented……..revised supply
                                      #33045
                                      hcraig244
                                        Tried a 22 ohm resistor in line with the regulator and this dropped the input voltage to a little over 10vdc…the heat dissipated by the regulator has dropped and the resistor is doing some of the work….P1016748 (Copy)
                                        #33046
                                        hcraig244
                                          As I’m now down to 1 bridge rectifier I thought it would be wise to check a few things out before I do a lengthy test run:
                                          Output from the new 6vdc regulator = 160ma under operating load
                                          Output from the existing 24vdc regulator (0tr1) = 440ma under operating load
                                          The transformer arms are good for 1.25A so I think we’re good to go, the bridge rectifier is rated at 3.7A. I will monitor the temperatures of all components, TR1 particularly though the data sheet says its good for 80w (seems high to me).
                                          Also I have ordered a 33 ohm 3w resistor to see if I can drop all the heat over it instead of the regulator, I can then fasten the resistor to the chassis for cooling……
                                          #33047
                                          hcraig244
                                            Resistor received, however I ordered a 3w component and received a 25w instead……bit overkill but quite adequate….P1016757
