Home Forums Product Discussion & Questions BeoLink Masterlink – Play button turns whole system off
Viewing 20 posts - 21 through 40 (of 45 total)
  • #74275
    carolpa
    So I just did some testing with some of my equipment:
    Beocenter 9300 – 7 pin datalink cable –  1611 – masterlink cable – Beolab 3500 MK1 both with, and without a powerlink cable between the BC9300 and the 1611.
    Beosound Ouverture – Masterlink cable – Beolab 3500 MK1
    In bot cases I get the same behaviour as you describe even when I start the music from the master system.
    Now what I expected. I will see if I have time to look more into this today
    speedsixdave wrote:
    Do you have the short circuit in your setups, @madskp? No idea if this is actually relevant or not.
    I am not sure. Most of my stuff is in a non permanent setup, so I often switch cables between different units. I will try to check up on this when I have some time, probably in a couple of days.
    carolpa wrote:
    Normal in ML : short STBY will stop only the product in the room addressed. Long STBY will put the whole system in standby.
    That is also what the manuals for the link products describe, so even more puzzling that I can reproduce this issue with two different Audio Masters.
    Will also try to look into trying with other components if the above does not change anything.
    The T1611 was designed to connect a non ML Audio to a ML Video – or – to connect a ML Audio to a non ML Video.
    In the proposed settting the Video ML/ Video non ML is missing. Maybe this is the cause of the behaviour.
    Note: I have a Beosystem 7000 – T1611 – BLC connected in my Netlink. I have to set the BLC up as VMaster to work correctly if I’m right (note: I have to check this though! Currently the Beosystem 7000/BLC is out of order, starting early next week it is up and running again).
    #74280
    speedsixdave
    SILVER Member
    Is that right? The 1997 Masterlink manual has this:
    BeoLink Converter is used when audio and video products with Master
    Link and Audio Aux Link (datalink) have to be interconnected.
    BeoLink Converter can be used in conjunction with both a video and an
    audio master. BeoLink Converter features autoconfiguration, meaning
    that it is able to detect automatically whether it is installed in a Master
    Link audio or in a Master Link video system. Configuration takes place
    when it is connected to the mains.
    BeoLink Converter can also be used as ML-driver*, which means that it is
    possible to connect e.g. a BeoCenter 2300 via the BeoLink Converter to
    the Master Link and thereby distribute sound to all link room products
    (see page 17).
    BeoLink Converter is used in compatibility setups (see the section on
    recommended compatibility setups, page 17).
    1161166
    Which I would interpret as ‘can be used in an audio-only setup’. Frankly I can’t understand why anyone would want to connect their telly to a multiroom setup, but that’s me being out of step I guess!
    Favourite Product: Beolab 3000
    speedsixdave
    SILVER Member
    @TK – thanks for all that helpful and interesting information. If I can attempt to boil that down to my own level of understanding. everything is ‘Language A/MCL’ from the invention of the Beolink 1000 and MCL2, up to the invention of Masterlink, which is then a new ‘Language B/ML’, and the IR-eyes are not doing any translating, just passing ‘Language A/MCL’ messages. Newer ML equipment is presumably translating the Language A signals to Language B and in the case of the BL1611, back again:
    Beolink 1000 > Language A/MCL > Beolink Passive > Language B/ML > Beolink Converter > Language A/MCL > Beomaster 6500
    Possibly I’m wrong and there is no independent Language B, it’s just Language A with a bigger potential set of commands.
    Anyway what I still think may be happening is that the short Standby command is being mis-translated or miscommunicated into Language B/ML. I presume this is happening in the Beolink Passive (or Active) but whatever circuitry is doing that mistranslation is bypassed if the Passive is used as an ML/MCL converter. This is definitely making my brain hurt a bit!
    speedsixdave
    SILVER Member
    At the moment I have no genuine junction boxes in ML cables, so there’s no shorting between pin 3 (wh/bl, ‘ML sensor’) and pin 12 (pink, ‘+supply voltage’), as recommended on pages 34 & 35 of this Masterlink handbook. I should be able to do this fairly easily at my distributor but not for a couple of days. Do you have the short circuit in your setups, @madskp? No idea if this is actually relevant or not.
    Wrong again, disappointingly. I set out to connect the white/blue and pink on my distribution board but found they were already connected, which of course they have to be in a ML-plug to RJ45-plug cable. So that’s not the answer to the conundrum. FWIW I tried disconnecting the pink cable entirely, but then nothing worked.
    Madskp
    GOLD Member
    I also had a little time yesterday where I tried to connect the White/blue and the pink wire i a ML cable and tried it withe the BS Ouverture + Beolab 3500 combo again with no difference in behaviour.
    I have a RJ45->ML connection to my wall mounted BL3500, so I guess I also had this connection already.
    Will try som othe combinations when time allows it
    #74324
    Madskp
    GOLD Member
    I had some time today to do a little testing.
    I tried different option settings on both the BC9300 and the BS Ouverture (opt. 0, 1 and 2) and on the BL3500 (opt. 5 and 6), but no difference in behaviour.
    I the tried to connect my Beocenter 6-23 to the setup, and now it works as expected and I can start a CD on the BC9300 (or the Overture when that is the master), join the Beloab 3500 with a single touch on the mute button and unjoin by another press ont the mute button. Also I can make a long press on the mute button and it will turn off the Master system.
    So it seems that a video master has some effect on how the system reacts to link room commands regardless of the use of a 1611 converter or a real ML audio system (Overture in this case).
    I will also try this with my Beocenter 2 to see if that also applies to a more modern ML audio system.
    #74331
    speedsixdave
    SILVER Member
    Well that is interesting, @Madskp, and I’m sorry I doubted you, @carolpa! It does seem a slightly peculiar state of affairs. Am I going to have to buy an old B&O tv and hide it in a cupboard somewhere to get a Masterlink audio setup to work properly?
    Now I’m wondering whether it has to be a genuine video source or whether it’s possible to fool the system with an additional source into the 1611 as in Matador’s illustration?
    Madskp
    GOLD Member
    I am not sure the 1611 can do that just based on sound input, as it might need the datalink signal from a TV.
    Another possibility is the NL/ML converter Carolpa mentions. If you do not need it for connecting NL equipment you might still be able to utilise it as a link room instead of an BL Active.
    I have a few other ideas that may not work, but will try to test them in the comming days and report back.
    #74343
    Madskp
    GOLD Member
    I can also try to test this in a stand alone environment to verify that it will work in that context
    #74360
    Madskp
    GOLD Member
    Had a little time again today.
    First I tried a long shot by putting a Beolink Video into the ML network. That did not work.
    Then I replaced the 1611 converter with a 1614 converter, and also added the 1611 into the ML network without anything other thatn ML and power attached to see if it would act as a V.master. That did not work either.
    Then I put the 1611 back, and added the NL/ML converter to the system configured as V.master, but that did not work either.
    So not much luck.
    I will try the test with the NL/ML converter again double checking cable connections to be sure everything is as it should be.
    #74390
    Madskp
    GOLD Member
    A little more testing today. Tried again with the NL/ML converter and some other cables, and this time it worked as expected so that is a possible solution for this issue.
    #74409
    speedsixdave
    SILVER Member
    That’s interesting @Madskp. With the NL/ML converter configured as videomaster?
    I was bidding on ebay for a cheap Beosystem 3 to try that too, but outbid. Hey ho. Not sure what I can try next.
    Madskp
    GOLD Member
    Yes. And I did just test it again with a IR eye and sepakers connected to the NL/ML converter, and it seems to work as a link rom and can join or unjoin while the music from the main system keeps playing (if started from the main system), and that did also work with the BL3500.
    So this could be a solution with the added benefit that it can also work as a link room.
    That could also be a possible solution, and would probably also work as a link room with speakers and IR eye connected. Probably the Beossytem 2 could also do this.
    #74784
    speedsixdave
    SILVER Member
    Well I missed out on the Beosystem 3 but have successfully outbid everyone else in the entire world on a NL/ML Converter which will hopefully arrive for the weekend. The madness continues!
    Madskp
    GOLD Member
    Hope this will suite you well. The NL/ML converter is a very versatile device and usefull for many type of setups.
    If you are going to use an IR eye for it be aware that you will need the newer type with a join button to be able to use the buttons on the IR eye. If you however only need the IR functionality you can wire up the one of the older ML or MCL IR eyes but only connection to ground, +5V and data.
    #74964
    speedsixdave
    SILVER Member
    That’s really useful to know, thanks. By chance I have an IR eye for a Beosystem 3 which has more connections inside than the standard round eye. Do you know if that would work with the NL/ML Converter? It’s just sitting in my spares box otherwise.
    Madskp
    GOLD Member
    That should work to my. knowledge as long as you just wire up the ground, +5V and IR data connections. You can find the connections diagram for all the round IR eye’s in the Beolink Handbook (available in the Beotech section on Beoworld). there is a diagram for Beosystem4 where it is wired up with RJ45 connection. This should be the one to look at, but only connect the 3 signals mentioned above.
    #76154
    speedsixdave
    SILVER Member
    Well my eBay ML/NL converter 1790 arrived on Friday, and a bit of time this weekend to do some testing.
    Firstly caveat emptor, my ML/NL convertor – apparently Hardware Type F according to the web configuration – is a bit crippled as it does not have ports for Powerlink, for Line In, or for an IR sensor. When I looked again at the eBay photos that’s clear, but I had not thought such things existed so failed to look closely. I did look at the software version etc, which seems to be up to date – 1.43 or something. Not a problem for this particular problem, but it does mean I’m not going to be using it for any other exciting purposes.
    After a lot of messing about with routers and IP addresses etc, I eventually got the thing connected to a web browser and was able to check it was set as V. Master. Then connected it to my Masterlink setup, turned everything on in hopefully the right order and… no change. Play button on  a ML-connected link device still turns everything off. I have not done extensive testing with lots of different IR eyes and devices but have tried various sorts of turning things on and off again.
    I’m still baffled and a bit disheartened at this stage. Mostly I think I’d be better off going back in time to the reliable MCL system and wiring the house and new extension for that, but it does seem a bit strange to hard-wire a new build with fairly obsolete tech. One of the attractions of ML is wiring with standard Cat 7 infrastructure which could be used for ML, PL, NL or even The Internet. Or I could go the other way to the modern world of NL and Mozart but that brings all its own issues of network configurations, audio delay, potentially vast expense and, god forbid, controlling things via a phone app. In so many ways Masterlink feels like the sweet spot but if I can’t turn a link room off without the whole system going into standby, it’s all a bit pointless.
    carolpa
    the BLC (NL/ML converter) is not “crippled”!
    the first BLC sold had these ports covered with a plastic strip. It, the strips, can easily be removed.
    then the PL, Line in and IR connections are available and working. See a picture of a later version to determine which port is which.
    #76166
    speedsixdave
    SILVER Member
    the BLC (NL/ML converter s not “crippled”!
    Amazing! You’re quite right. Thanks @carolpa! I’ve peeled off the white plastic strips and there they are – two more RJ45 ports and two Kinch/phono sockets. That’s a world of future fun if I can ever get it configured properly!
